Results 1 to 8 of 8
Thread: How do you change the fuel pump in the VS commodore
    VL group A Brock
    May 2006
    Default How do you change the fuel pump in the VS commodore
    Just wandewring if this has been discussed, if so could someone piont me to the thread, or if not, how is it removed.
    I went to pull mine out and got it about quarter of the way out and looks like the big black hose that connected to it wouldnt budge from inside the tank, so instead of me getting the shits and really pulling at it, is there some simple way of doing it.
    thanks appreciate it.
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    hey mate you did it somewhat right, that black hose has a hoseclamp looking thing on it that undoes but also does up again..so just unlclip it from itself, remove ur pump and sender unit, change over the pump and put it all back in..when ur half way in put the clamp back onto ur black hose and then proceed to fit it all up again. also possibly once removed do another fuel pump housing gasket (if its not supplied) good chance of it weeping.
    VL group A Brock
    May 2006
    Yer mate I look where it may undo, but looks like it clamped on with fliers or similar, cant work out how to undo it unless I brake it off, any ideas ?
    vt 5litre aussie hydrolic roller worked
    Feb 2012
    narellan
    id just un clip the clamp with a screwdriver or door trim pick an try keep as much of the hose as possible, then just hose clamp it on, remember too mate, your dealing with fuel an aprks ignight fuel,,,, if your upgrading your fuel pump or using 1 witch doesnt just clip on then be sure that it isimpossible for the wires to ark or spark at all, heat wrap each wire twice each atleast whererver joined an then heat wrap both togeather, if ya unsure man then make sur u get it checked out by a pro cause 1 stuff up an ya better be insurred
    vs commodore
    Oct 2009
    Tamworth NSW
    Some of these internal fuel return hoses in the VS use a type of "quick connector" to connect to the fuel pump/gauge assembly, and this connector needs a special tool that fits into it to uncouple it. The tool basically has two, 2mm wire prongs, about 1 cm apart, with rest of the wire bent down to make a sort of handle for the tool. The gregories workshop manuals show a pic of this tool.
    VS S Pack
    Sep 2009
    Brett is it the same tool that you use for the fuel fittings on the firewall?
    If so you can get them at Repco or Supercheap
    vs commodore
    Oct 2009
    Tamworth NSW
    It looks completely different from the round quick connector release tools that are used on the fuel line connectors at the firewall in the engine bay. . The manual says this tool is available from SPX australia. Its a bent piece of wire basically. I just used a piece of wire to get mine undone. It took a bit of stuffing about,but it came undone.
    VS Statesman 5L
    Dec 2011
    Tom Price WA
    Default Internal fuel line
    does anyone know what this line is for in the tank? and what the white bit on the end of the Line (inside the tank) is for. replaced my fuel pump but the said line was perished. I couldn't find any info from a number of holden joints so have just replaced with a fuel line and will see what happens?
  1. VS commodore CAS or Fuel Pump? Fuel pump new BUT not priming on accessories
    By robert422 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 08:14 AM
  2. how do i change vs fuel pump??
    By sjbucko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2011, 05:02 AM
  3. HOW TO change FUEL pump
    By MAC-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2010, 06:46 PM
  4. How to Change Fuel Pump in VP?
    By surfrun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 08:03 PM
  5. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
