Hey
So Friday I drive the car 10kms down the road, no problems not a sign on trouble.
3hrs Later when I was leaving the car seemed really sluggish, almost as if it was missing. It happened until I arrived at my next destination, where I left the car for another 3hrs. When I went to leave the car was fine, no signs of the problem and ran as per normal. I've done about 120kms since then, no issue.
Today on the way home, I gave it some juice to overtake, but as soon as the revs came down it started to happen again and has proceeded to until I was coming up my street and it went away again.
Its hard for me to describe. I get upto 2000rpm before it starts. I'm not entirely sure what missing feels like, but at best guess this would be it. You can feel the car shake and hear it through the exhaust, and the more I try to accelerate the revs falter a little and then it just kicks to life, changes gear and starts again. This only happens when under load above 2000 rpm.
I've tried diagnosis with a laptop but the problem wasn't occuring by the time I plugged it in. There are no logged codes. Im kinda at a loss here.
After a couple of searches plugs, leads, injectors, filters and coils all seem to come up. I just don't want to go replacing everything hoping it will go away.
Any help would be tops, thankyou
I replaced the headlights in my car with strobe lights, so it looks like I'm the only one moving
I would replace the plugs and test the leads. There should be something on here on how to test them.
Anthony.
I would check fuel filter as well... The number of times i have seen a high pressure inline fuel filter put in the wrong way causing fuel starvation.... :P
Ok, so I tested the leads and got 4-6k ohms on leads 1,3,5 and 2-3k ohms on leads 2,4,6. Is this low? These are genuine holden leads and have been in there for a while.
Checked the fuel filter, looked ok
Managed to get a spare coil, will replace one at a time and do a test drive tomorrow, only problem is that that the missing/sluggishness is only present intermittently.
Also dug through some reciepts, fuel pump was replaced 30 thousand km ago, so it should still be good?
Thanks for help, any more would be appreciated
Sounds like coil packs my mates vs executive did the exact same thing we pulled them out an used another friends one to test it which is about a 5 to 10minute job an it was fine so then just replaced the coil packs an hasn't missed a beat since..
Just tested the coil packs, the missing is slightly better but definately still there, I tested 2 different coil packs in each position (I have 2 spares).
Am going to try diagnosing with the laptop again, hopefully I'll get somthing usefull. Any other suggestions?
Just did a laptop run and managed to get it.
I've posted the log (only 15 secs long) and the missing happens badly between 6 and 10 seconds. I've been looking at it but not sure what is exactly wrong. If anyone with some knowledge of this stuff could have a quick look it would be great.
Note: jc wouldnt let me upload it to the site so i threw it here:
http://www.filedropper.com/bigccc
dude its not there
is it a pic or a vid?
Sorry should have said, its a log recorded with an aldl cable using tunerpro. I could take a video of it happening if it would help.
oh ok that would explain y i cant c it. i havent got tunepro
lol
I have tunerpro I'll take a look at it in 10 minutes
hmm the log file doesnt want to load
Engine temp looks to high and O2 sensors indicating lean.
I think that the O2 cross counts should be higher if in closed loop.
muttley383
I forgot to mention, post on the delco hacking site as they have all of the guru's that know tunerpro backwards.
muttley383
Yep temp is too high may be the throttle position sensor and take out the 02 sensor out and see if u can clean it up
Can you also put some screenshots of it at idle? And also of the DTC fault codes?
Definately WAY hot and it's time for new Oxy Sensors by the looks of it, Although they wont be the cause of this issue me thinks....
MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
Ok, I did 2 more laptop logs which I will link below (still cant upload direct to site).
I also noticed that the problem doesnt occur in 1st gear no matter how I drive. But as soon as I hit 2nd it starts. Also, after the problem happens, I put it in neutral and rev it quickly to 3000 and the exhaust will crackle or pop, but only straight after it happens in gear.
So from this, I would think that the pop is the unburnt fuel igniting in my exhaust?
Thanks alot guys, you've been really helpfull.
I'll also see what the folks at delco hacking would recommend.
Files: Free File Hosting - Torrent - Megaupload / Rapidshare (Fault occurs throughout the entire log)
Free File Hosting - Torrent - Megaupload / Rapidshare (car idles for 10 seconds, drives into 2nd, then when i build revs the fault occurs)
http://www.filedropper.com/efiliveidleandfault
Heres a log I took with efi live v4 and a video for your viewing pleasure!
