Results 1 to 13 of 13
Thread: VR Engine swap now i have nothing?
    VN Berlina
    Jun 2006
    Default VR Engine swap now i have nothing?
    as the title goes, swapped the engine over as i had a spun main bearing. would still start with the old engine in. and the new engine was taken out
    after i had seen and heard it going in the other car so i know it runs.
    but now i get nothing, no lights, no stereo.. nothing... nothing electrical will work. turn the key and nothing.
    have checked as many things as i could, battery, fuses, plugs etc but cant figure it out.
    really need some help.
    Cheers, Jason.
    Series 2 VR Commodore
    Jul 2010
    Wilton/Sydney
    VN Berlina
    Jun 2006
    battery was dead, so tried jump starting and had nothing so took the battery out of my falcon and put it in and still nothing.
    battery out of the falcon is fine.
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Sounds as simple as somethign not hooked up. If you have NO power to ANYTHING, well id start with the battery and all connections that power these things.
    Not sure on a VR, but VS has a 2 part engine harness. 1 main plug cluster to the ECU and the other to the battery and all the fuses.
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    vs calais 355 supercharged
    Feb 2012
    gold coast
    VS S Pack
    Sep 2009
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Get a multimeter or test light and start tracing your missing volts
    http://woteva.tk/
    If it ain't broke... I can break it for you
    few commodores
    Feb 2011
    victoria
    both earths, 1 on the engine block near the drivers side engine mount, the other going straight to the body near the battery?
    Oct 2011
    there are actually 2 earths on the engine block itself. one above the other. and all it takes is one missed wire and boom you have no electricery
    few commodores
    Feb 2011
    victoria
    meant the 2 main earth's from the negative terminal, the 2 other's near the water pump won't effect having no lights etc on the car just play havoc with the ecu and efi etc, engine will still turn over if they're lose just not run.
    VR Statesman 5.0,
    Jan 2012
    NSW
    to have no radio or lights, id be going for main fuse or you havnt connected all leads to posivive terminal.
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. engine swap?????
    By QKVNV8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2010, 04:52 PM
  3. engine swap
    By Nervegas in forum General
    Last Post: 04-08-2008, 05:53 PM
  4. engine swap
    By venerableChicken in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2006, 08:46 PM
