Results 1 to 7 of 7
Thread: VS Manual Stalls when stopping
    VR Calais
    Mar 2011
    Plumpton
    Default VS Manual Stalls when stopping
    hey guys i just finished converting my vs s pac to a T5 manual, iv had the ECU memcal retuned and had all the auto codes and errors removed, but some times ill pull up to a set of lights and the car will drop fairly low in revs and stall, i have wired the speedo, from the speed sensor straight to the harness that goes to the cluster so the ECU reads that theres no speed signal, the fella that did the memcal for me told me that the ECU needs to recieve a signal from the speed sensor to stop this stalling issue
    has anybody fixed this issue?? how could i fix it??
    any Information will be greatly appreciated
    Thankx guys n galz
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    VR Calais
    Mar 2011
    Plumpton
    How would i fake a signal?
    Ghost's Avatar
    Sep 2011
    A retuned memcal is no good u need the specific ecu for manual to auto because there is different setting on the ecu itself replace the ecu with the manual one and all your problems will disappear
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    manual ecu and loom.... or, see a tuner who is good with tweaking the IAC steps.
    I converted my VS to manual, still runs auto ecu and loom. Used to stall like yours, but after my tuner had a play its sweet as now.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    as above. the auto ECU's generally do not have the components to read the T5 VSS signal.
    so you can find a genuine VS T5 ECU, or I believe you can get converted auto ECU's off eBay. Never tried the converted ones, but if all the components have been fitted, there shouldn't be any problems.
    A temp measure that most people do is to adjust the idle screw in a bit to keep the revs up.
  1. Car stopping in traffic
    By Chain in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2011, 07:38 AM
  2. VY V6 stopping intermitantly
    By synon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-03-2010, 02:47 PM
  3. VS Ute V6 Stopping
    By 1Monaro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2009, 02:29 PM
  4. Car Just Stopping
    By FrangaVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2008, 11:57 AM
  5. stopping
    By executive_power in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 09:35 PM
