Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Like Tree16Likes
Thread: Where is the cam angle sensor
    VS Calais S2 L67
    Jan 2012
    esperance
    Unhappy Where is the cam angle sensor
    Hey all,
    I did the trick with the fault output plug with shorting port 5 and 6 together with a wire and the code that came up was 48 which is cam angle sensor its on my L67 I just need to know where it is and how to replace it
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    it's crank angle sensor,it sits behind your harmonic balancer an looks like this.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    When ever I do the Crank Angle Sensor I always try to do the balancer as well if it looks pretty old. Could even through on a Powerbond balancer they work much better then factory.
    VS Calais S2 L67
    Jan 2012
    esperance
    VZ MY06 executive 3.6L
    Feb 2012
    i have to change my cramk angle sensor but on the balancer one of the holes has no thread for the puller so i had to put it in to the mechanic for them to sort out,
    they know how to make money coz its costing round bout $100 and thats me supplying the sensor, ($40) ebay.
    it would only take under an hour to do.
    I live my life a corner at a time
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Have you considered all the costs in running a workshop?
    Mechanics have to eat too you know.
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    I would pay $100 in labour to never have to touch another harmonic balancer!!!
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by kaino View Post
    Did you even consider a slightly bigger bolt for that hole?
    VS l67 statesman
    Dec 2008
    VS Calais S2 L67
    Jan 2012
    esperance
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    Kaino, 100 bucks is more than fair. considering its not an easy job to do. count yourself lucky as most mechanics will charge upto 100 an hour in labour. and that would be at least an hours work, maybe more when you think about it
    they have to take everything out thats in front of it, then sort out that dodgie hole and then do everything in reverse. so count yourself lucky
    edit: whoops, sorry chargd, i need to redirect this comment as i just realised that even though u r the OP, you didnot make the comment im reffering to. lol my bad
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by aussie4life11 View Post
    chargd, 100 bucks is more than fair. considering its not an easy job to do. count yourself lucky as most mechanics will charge upto 100 an hour in labour. and that would be at least an hours work, maybe more when you think about it
    When I did mine I never had to remove the radiator or the fan :P
    With the right tools the job is easy.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    The CAM angle sensor is located just above the water pump pulley in the timing case. It is held in by a 10mm bolt. You may have to get some light to see it.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Its a half an hour job at the most, and its a piece of piss to do.
    It's amazing how the original post clearly states that he is after the LOCATION of the CAM angle sensor. Yet 1 person put the image of a Crank Angle sensor and nearly all of you have gone the completely wrong direction to what the OP wanted. Why did you do this? Because you're all Idiots!
  15. #15
    95 vs commodore v6 3.8l
    Feb 2012
    upper coomera
    atleast im not the only one that picked that up different sensors almost sound the same hope he listened save himself alot of heartache and money
  16. #16
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Black_Stig View Post
    I am sure the OP has found it by now .. for awhile I did not know where it was until I unplugged it by mistake thinking it was the CAS hehe, I felt rather stupid too.
    Anyway my response was only to aussie4life11.
  17. #17
    Oct 2011
    lol james. all i was sayin is that its easier to access if you take them out. id hate to be doing it and slip and break the radiator or something.
    stig, i know that the OP is talkin bout the cam angle. my response was about a complaint by kaino. was directed at him, no-one else.
    and for the record,stig, your head is so far up ur ass that u dont see that ur ranting about us being idiots, well wat about u in my thread perfect harmony? in that thread i asked for a home job to get the harmonic balancer off. you and alot of other ppl decided to give me financial advice and couldnt see what i really wanted. so get off ur high horse and stfu. cos u no betta dan the rest of us.
  18. #18
    Oct 2011
    NO YOUR WRONG… the CAM angle sensor is actually ABOVE the HARMONIC BALANCER and UNDER the water pump pulley and it is NOT inside the timing case at all its bolted outside..
  19. #19
    Oct 2011
  20. #20
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Quote Originally Posted by VR_V6_MANUAL View Post
    Never said it was INSIDE the timing case, I said it was IN the Timing case, because technically the Magnet sits IN the timing case. It sits just underneath and to the side of the water pump. None the less, its really hard to stuff it up with the CAS sensor.
  21. #21
    Oct 2011
    Well i was just correcting you because you said its above the water pump in the timing case…. and i know its really hard to stuff up with the crank angle sensor but not everyone out there knows a lot about cars and some people need a little help… We all started somewhere there was once when i didn’t even know how to change my oil. So anyways i was just correcting you because you gave him the wrong location and yeh he probe was looking for the wrong thing in the wrong place which would of gotten him nowhere..
  22. #22
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Either way its still hard to bloody miss it, considering its the ONLY sensor bolted into the Timing case.
  23. #23
    Oct 2011
    Yes i know it is.. but he might not of known its the only sensor on the timing case.. but anyways he knows now so its all good
  24. #24
    few commodores
    Feb 2011
    victoria
    i'd say 15 mins to unplug, undo 1 bolt, remove, reverse procedure, clear ecu, drive away, still don't get why half this thread has nothing to do with the OP's sentence, code 48, 6 cylinder = as he said cam angle sensor.
  25. #25
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Quote Originally Posted by Jxw View Post
    Yes thank you GENIUS..... Think all that was covered back in my first post here, that's if you bothered to read the whole thread.... Idiot!
  1. VR Cam Angle Sensor
    By BRiNGiT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2010, 12:15 AM
  2. Cam angle sensor.
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 11:11 AM
  3. Crank Angle Sensor
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2007, 11:49 PM
  4. CAS Crank Angle Sensor Help please
    By kezza_4246 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-08-2006, 05:07 PM
  5. Cam Angle Sensor?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2005, 06:49 AM
