Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By SavVYute
Thread: Brought vs with driving problems
    vr/vs
    Feb 2012
    Altona north
    Default Brought vs with driving problems
    Hey everyone,
    Im pretty new to this site, hoping i can get some help from here, ive been looking through the forum and really think this forum is top. Anyways ill start with my car problem and ill introduce myself later.
    So i just brought a vs acclaim for $450.00 of cause a car that cheap has problems, its a v6, auto, duel fuel. Theres no LPG switch as the owner said the LPG doesnt work and he said something like when he turn it to LPG it wont rev, i really dont know what he means but anyways i been driving it on petrol and theres been a few problems i hope you guys help.
    When its on park, i rev it up and it kinda looses power from 1000-2000 rpm then it revs ok, But when i put it on drive it drives ok but still kinda lacks power abit, sometimes when taking off, the car looses power and the same time when it tryes to regain power it shutters in the middle section of the car, it kinda sounds like the tail shaft.
    I dont really like the fact of driving the car with LPG especially not knowing the condition of it, is there a cut off switch somewhere in the car where i can turn off all the valves or something?
    The engine bay looks different to a petrol vs, Dont know what is safe to remove or what is not, is it hard to remove the gas setup?
    Anyways that will be it for now i really hope i explained it properly enough, if i didnt please tell me, really looking forward to your help
    VS
    Jul 2010
    Sunshine Coast, Queensland
    First of all, Dont touch the gas. Dont remove any components. There should be a valve on the tank itself under a small cover that will stop gas escaping from the bottle. Sounds like a sparking issue to me, DFI, coils, leads and/or plugs. Your best to do yourself a error code check and report back with what you have.
    Heres the link on how to check them. Checking error codes VR/VS (Revised)
    Click the link in my signature to find out what the codes mean.
    Let us know how you go and what you get.
    May 2006
    vr/vs
    Feb 2012
    Altona north
    Checked the error codes and it came up 12
    Quote Originally Posted by lease1 View Post
    Where did you bring it from?
    where did i bring what?
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    vr/vs
    Feb 2012
    Altona north
    yeh flash 3 times why you ask that? is there a reason for how many 12's...
    Ghost's Avatar
    Sep 2011
    When diagnostic mode is activated it cycles through the codes that's all so some times it will flash 12 then 47 then 12 again
    vr/vs
    Feb 2012
    Altona north
    the error codes still come up 12, still need help with this problem if anyone knows can you please put your 2c in this thread, thanx
    VB SL/E
    Dec 2008
    Sell it and buy a good one before this one costs you more than you bargained for. Just my 2cents.
    VY S V6 Ute Series II 2004
    Nov 2009
    LOL ...Where's the fun in that?
    I'd have a go at fixing the old girl .. you'll learn heaps and might end up with the best car you've ever owned.
    $450 for an Acclaim dual fuel = bargain
    vr/vs
    Feb 2012
    Altona north
    k so i went for a drive which involved freeway driving and trafic condition, i noticed that it struggles under load very much, also when around 95k's and accelerate the car shutters heaps, feels like its in the middle of the car.
    Can someone please trouble shoot this problem for me, i thought it mnight be spark plugs but i reved it on drive holding the brake down and it seems to rev nicely, doesnt seem to miss, Would the tail shaft cause all those problems? it seems to loose power between 1000-2000 revs.
    few commodores
    Feb 2011
    victoria
    if you put it in D or 1st and hold the brakes down hard and accelerate slowly (without moving) does it still break down and miss?
    as above, replace the basics, plugs, leads, air filter and see if that makes a difference, if that makes little/no difference then check the fuel supply, filter, reg, pump....
    the vibration sounds like something in the tail shaft, uni's, cv joint but most likely the center bearing
    vx ss commodore 400hp+
    Jan 2012
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the shudder i'd go with the center bearing. stuggling as a couple members suggested, plugs and leads.
    give her a good service, change all filters, oil, air, and fuel.
  15. #15
    vr/vs
    Feb 2012
    Altona north
    K thank you guys for your help with diagnosing the problem. Ill give the car a full service tomorow, hopefully itll help and solve the problem. because at the moment when taking off theres just no power in it, just slow. Im hoping its the spark plugs, will let you all know what happens
  16. #16
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    are you sure its taking off in first? cos take off can be sluggish if its stuck in LHM(limp home mode)
  17. #17
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    codes would have been logged if it entered LHM
  1. Just brought yet another vl...
    By Nackerz in forum VL
    Last Post: 15-04-2012, 09:29 PM
  2. ignition problems and sometimes cuts out while driving
    By brjg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2012, 09:45 PM
  3. Recently brought VL from my brother and has intermitent ringing when driving.
    By jdl6666 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-01-2012, 06:18 PM
  4. Problems while driving
    By Ram85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2010, 01:51 PM
  5. Anybody brought or used these?
    By Fun_Bucket in forum Car Audio
    Last Post: 17-05-2009, 12:26 PM
