Results 1 to 3 of 3
Thread: Knock Senor WHAT ????
    VR Statesman
    Feb 2012
    Port Macquarie NSW
    Default Knock Senor WHAT ????
    Hey blokes
    I have a 1994 VR Statesman 5Litre and have brought a HSV Chip and it requires a Knock Sensor ??
    So i now have a HSV 185 Chip and a Knock Sensor
    Now what do i do ???
    ive been reading that you wire the knock sensor to the ECU ?? But my knock sesnor doesnt have a wire ??
    Where do i mount the knock sensor ??
    the chip installing seems easy take out the standard one and put in the the HSV Chip
    the only thing is the wiring of the knock sensor
    do i just make my own wire??
    is the a standard one there?
    HELP !!!!!!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by BlackVXGTS View Post
    If you run on 98 octane fuel you shouldn't need a knock sensor.
    Thats not entirely true. I run 98 and a knock sensor on a engine running 10.7 comp, think of it as insurance agaist dodgy fuel.
    You install the knock sensor on either side of the engine, the side with the most clearance from the extractors. You need to remove a bung and install the sensor, wiring kits are on ebay and you just add a pin to your ecu connector.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  1. crank angle senor ?
    By bones308 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2011, 07:28 AM
  2. 304 5L V8 air temp senor? where is it??
    By ducker85 in forum V8 Development and Modification
    Last Post: 10-12-2010, 05:42 PM
  3. 5L V8 air temp senor? where is it??
    By ducker85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2010, 04:19 PM
  4. oil temp senor
    By slaughtknight in forum General
    Last Post: 15-02-2010, 09:42 PM
  5. knock knock bloody knock
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:39 PM
