Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: High speed shudder
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default High speed shudder
    Hi Guys.
    I got my new wheels fitted a few months back (17" with cheapo zetum tyres)
    I had them balanced from bob janes when I bought them but it didn't really feel right around town and at 110km/h on the freeway the wheel was shuddering like crazy.
    So I took it to bridgestones near my place and paid to get it rebalanced again, they said bob janes had done a crap job and they had fixed it.
    But its still shuddering just as bad at 110 like the wheels were never balanced in the first place.
    I have a 1200km round trip coming up next weekend all sitting at high speeds and would like to get this fixed before I go for safety and comfort.
    Anyone know what could be causing this, its been balanced three times now and still no difference....I have jacked the car up and no play in the wheels so its not tie rod ends.
    Car is a 96 VS live axle on Superlows and monroe GT gas shocks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    BANNED
    Feb 2010
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by someguy360 View Post
    Hi Guys.
    ^^^ That will most likely be your problem.
    Visit my Facebook page
    Monaro v2
    Jan 2010
    Gold Coast
    Put some different wheels on your car and take it for a test drive. If it still shutters with different wheels then check all your bushes and wheel allignment.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by beauzo View Post
    Don't have any spare wheels, but will check over all the bushes....I did replace them all within the last 6 months.
    Don't know if its the cheap tyres as I have had them on previous cars and a couple of mates with commodores have the same ones and they are ok too
    EVIL304
    Oct 2011
    Hello Someguy, if its not the new tyres maybe check to see if one or more of your brake discs is bent slightly and not running (spinning) true.
    EDIT - Thats only if its happening whilst braking.
    Monaro v2
    Jan 2010
    Gold Coast
    did you change your castor bushes? If your control arm has any movement in it, it can wobble when you get up some speed.
    VS Equipe
    Jan 2011
    Adelaide, SA
    All bushes are good, had it up on the hoist and went over everything on the weekend (there is a bit of wear/play in the rear lower control arms but the shudder definitely feels front end related)
    The shudder seems to be occuring at low speeds too (60,70 when cruising in 4th) and also when braking......then gets particularly bad between 100-120km/h
    The only thing left to try is the tyres so I have a mate bringing a set of stockies with RE92's down tonight to test and see if it makes any difference.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ahhhh...more info comes to light.
    The shuddering under brakes will be warped rotors. Sometimes this can cause a high speed vibration as well.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Well its not happening just under high speed anymore.....its also just cruising at 60 its not really noticeable at that speed unless your paying attention but its still there
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    See what happens when you change the wheels over.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by IBLOWN View Post
    Why is nobody asking if the correct wheel spacers are fitted to the hubs?
    Didn't even know I needed any spacers
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    No matter how much you balance the tyres they need to be round to prevent vibration.
    You get what you pay for.
  15. #15
    1992 VP vacationer
    Nov 2009
    yup, cheap nasty rotors that are warped because they are crap! can indeed be unbalanced and cause vibration. you will be surprised at how many brands of rotors are not balanced. I bought Brembo under the IBS brand name and these were clearly balanced as you could see where they had machined out some metal at the edge and the other side rotor had a counter weight clipped in one of the vents.
    Great rotors in fact the best I have used no cracking, no warping, balanced and I have flogged the absolute shit out of them for well over 60k so far and still nothing wrong with them except a fair bit of metal is gone, but that's just me driving
    my last set of rotors did vibrate a little at high speed.
  16. #16
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Its possible that its your brake rotors as mentioned, but, that said, my mates VZ had a wheel come off at 80km/h and naturally he hit the brakes and the car landed on the rotor which was locked up and has put a huge flat spot on it. Its taken off about a 1/3 of the rotor on one part but it doesnt vibrate or even shudder under brakes, which is pretty amazing, even more amazing is that he still hasnt fixed it and it still passed a roadworthy lol.
  17. #17
    VK SL 5spd
    Sep 2009
    Wagga Wagga
  18. #18
    VS Equipe
    Jan 2011
    Adelaide, SA
    Thanks guys, just remember this problem isn't only apparent during braking, lots are jumping to brakes right away, the problem is almost as evident when cruising (even at low speeds such as 60)
    I put a set of stockies with toyo tyres on the front, made no difference.....trying the rear tomorrow.
    Only things left that haven't been replaced are front and rear lower control arm bushes, the fronts seem ok, a tiny ammount of play when attacked with a crowbar and the rears aren't great but it still feels more front end related......every other bush has been replaced
    If the rotors are indeed warped would I notice that when I am driving, the problem is just as apparent with my foot on the accelerator.
    Could it be bad front shocks, the rears were replaced with monroe GT's when I lowered the car but the fronts are still original (date stamped 1997), could worn shocks cause these symptoms?
  19. #19
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    regarding warped rotors (i am aorta getting a similar problem but it goes away and comes back when driving)
    how can you tell if they are warped?
    i did take all weight off the wheel once and was spinning it and every once around it would have tge rotor on pad noise. but not enough to slow it down.
    would that be them because they are warped?
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
  20. #20
    VS Equipe
    Jan 2011
    Adelaide, SA
    Ok so tested stockies on the front, still the same
    tested them on the rear...still the same
    Got it back off the ground today.....all front end bushes have been replaced with fresh nolathane bushes which are tight as a drum.....exept the front control arm bushes which look like this
    They have a little bit of play when attacked with a crow bar.....could this be my issue.
    I also had a look at my link pin bushes, do they look to be installed correctly? they don't look like they are sitting properly to me (should there be that gap between them?)
    Other than that i'm not sure what it could be other than rotors which is wierd as the problem occurs while driving and not just braking
  21. #21
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Did you try four stockies at the same time?
  22. #22
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by RX25SE View Post
    no did the fronts....noticed no difference then did the rears noticed no difference.
    so all 4 wheels were swapped at different times to eliminate a flat spot in one of the tyres etc.
    I'm thinking its fairly safe to say is the front inner control arm bushes.....they have play in them and after some more in depth searching others have had the same symptoms and replacing them was the key.
    Car is booked in with the mechanic to get some work on the exhaust done this week so will get them to press some new bushes in and see if that fixes it
  23. #23
    EVIL304
    Oct 2011
    I had this problem and it ended up being warped rotors. It was also noticeable whilst I was just cruising around, i would certainly look into it.
  24. #24
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by 5LVTSS View Post
    Yeah, well the bushes are still due to be replaced so I will do them while I have access to the press
    I will also machine the rotors while I am there.
  25. #25
    Monaro v2
    Jan 2010
    Gold Coast
    wow! a lot of people threw opinions at you mate, did you find the problem?
  1. Replies: 5
    Last Post: 23-03-2011, 12:20 PM
  2. Steering Shudder at High Speed just after Rotate/Balance
    By BakeTheTank in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-03-2011, 07:24 PM
  3. vz sv6 problem. shudder at high speed
    By ROLNBG in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-06-2009, 06:50 PM
  4. vibration/shudder problem @ high revs VZ Calais
    By goodday in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-04-2009, 11:46 AM
  5. Front end shudder at speed
    By Pretender in forum General
    Last Post: 28-10-2005, 08:57 PM
