Results 1 to 7 of 7
Thread: VS Auto Gearbox Issue, or Something else ?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Exclamation VS Auto Gearbox Issue, or Something else ?
    Hey everyone
    Today I went down to Sydney, went fine going down.
    However when coming home I had traffic before reached the freeway, the shift from 1st-2nd felt harsh almost like it was banging into gear.
    When I got back onto the freeway, I went to over take someone, when I tried to accelerate the car just vibrated and would not change down gears or gain any speed at all. This happened every time I tried any sort of acceleration, I got home put it into Park then back into Drive, it then did like it did from 1st to 2nd (went into gear harshly, and car started to vibrate).
    Later on, I went out, started it, put it in Drive and it went in smooth and the shift harshness from 1st-2nd was gone.
    I have no idea what it could be, any help will be appreciated.
    VS l67 statesman
    Dec 2008
    VS S Pack
    Sep 2009
    have you checked your fluid level and when was the last time the fluid/filter were replaced
    could be the shift solenoids starting to play up too
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    I have suspected the TPS for a while as constantly even when in first it doesn't really get moving until you put the boot in (feels lazy), I haven't checked the fluid levels yet.
    I will service it soon, but I don't think it would explain why it, shifted perfectly afterwards.
    VB SL/E
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd agree with all the posts above - and add that the problem will return so you must really find out what caused it. To check for fault codes see:Checking error codes VR/VS (Revised)
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by hsv91ss View Post
    Probably because the fluids had settled back in the pan... when it gets hot the problem may happen again.
    Best to check the fluids while the motor is running and when it gets up to temp...
    People tend to neglect the Trans and then wonder why they have problems.
  1. Auto gearbox handbrake issue
    By Stewlz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-12-2011, 03:13 PM
  2. T5 gearbox issue
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2011, 09:12 PM
  3. Vy auto gearbox issue
    By Elite58 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2011, 10:56 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. Gearbox Issue!
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 01:16 PM
