So yer basically as the title says, when I drive my commodore it sounds like its firing off of only 5 cylinders, expect it happens pretty randomly as well. Not always when I put my foot down but sometimes.
Its not the spark plugs or leads because I changed them, and its not the fuel filter getting blocked becasue I just replaced that this morning and it still sounds the same.
My only guess's now are maybe fuel filter / DFI module / Coil Pack
Any ideas?
I would suspect DFI and/or coil pack.
Unlikely to be a blocked injector...
i would change the dizzy cap and rotor... get a new coil and fuel filter because there cheap
if it still does it borrow a mates ignition module and try that
then if all that fails check all injectors
If in doubt......FLOOR IT!!!
+1 for DFI or coil pack
haha whoops... disregard anything to do with a dizzy then
Test the coils for good spark, if they are sparking fine along with the plugs and leads then start looking for a dud injector.
What I did was unplug the connecter on each fuel injector one at a time while the motor was running. The one that made no change to the idle was suspect so I checked the spark plug and the coil for spark. If they were ok I then checked the injector.
In my case the injector was completely blocked....
