Hey guys
Before anyone jumps down my throat i searched before posting this..
Anyways i finished putting my ecotec into my VR its all up and running good but the speedo wasnt working due to not being connected.. So today i went into this thread The complete Vn-Vr Manual Conversion Guide. and wired up my speedo the exact way it says.. But my speedo STILL doesnt work. any advice on why its not working??? Also if it helps the speedo was working perfect before i put the ecotec in…
IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
MY DAILY NOW WITH ECOTEC CONVERSION
http://forums.justcommodores.com.au/...ml#post2145177
so your still using the VR computer? or did you swap it all over?
if it's a T5 then it wont work on a auto computer as it's missing components to read the T5 sensor. See link VS Manual vs Auto PCM you will also need a manual tune or can use auto tune with VSS switched but just easier to use manual tune. I have done some auto to manual pcm's in the last week by adding those parts but yet to hear back if it's working reliably. Finding a manual pcm is rare or expensive. If your interested then pm me i can let you know how the converted pcm's go.
The1 your inbox is full so ill just hijack this lol forgot to add that the resistor goes within 150km of switching over to fuel my friend mainly drove it on LPG and would only switch over to fuel once every two months just to keep the seals good
And to answer the op if you got the mace tune yourself did you tell them it was for an auto ecu on a manual box because if not then your still at square 1 u need the auto functions of the ecu disabled or an adapter to convert it but of you have the money get a manual ecu
I'm not to sure on that you either have a wire problem still or the cluster is playing up
Well then there maybe a short in the wire or the sensor is rooted
And another bit of food for thought I'm not sure but there maybe an issue with the bcm I'm not sure if it was changed in anyway between vr and vs
Im still using the VR bcm. This might help but not sure.. Im using the Vr body harness and bcm but im using the Vs auto engine harness plugged up to the auto computer and vr body harness
Sounds a bit dodgy if I was going ecotec I'd strip all the wiring and put all vs in but we will wait for now and wait for the1 to give some more input lol as for now if it's a car your driving all the time use a gps to track speed
Narh its not dodgey cause the VS body harness is pretty much the same as the VR body harness.. Yeh might haft to take mine for a spin to towoomba to pay him a visit![]()
I'm in nsw lol but later on down the track I'll be going right round Australia and I'll be posting my location to where I am so I can spend some time with other members with their rides but that's a few years away yet
have you got power and earth hooked up to the speedo sender?
Ok I'm gonna have a stab in the dark try switching the manual sensor with the auto one and make sure the manual cogs are on the auto sensor and see if that works
