Hey guys i bought a diff and the guy said it was an LSD but wasnt sure! i jacked it up and when you rotate one wheel, they both spin the same way! so it sounds like a LSD? and i got my brother to hold one wheel and and if i turn it hard it does spin in the opposite direction. Here is a video of it ! ( cant see much because one bolt is rounded off, so the covers not fully off) LSD - YouTube
from that quick glance it does look like an LSD. would have been easy to answer if you got the cover off!
if you look at the opposite side (the other side of the center from where you are focusing) you will see two 'rows' of bolts. One set hold the ring gear to the center, the other smaller set will be the LSD carrier bolts.
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.03 @ 103 Mph... A 12 is but a run away! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily Senator rep: http://forums.justcommodores.com.au/...ite-vr-ss.html
Thanks mate for taking the time to look! this is great news!
