Results 1 to 3 of 3
Thread: tight spots
    95 VS Acclaim
    Mar 2012
    ACT
    Default tight spots
    Hi,
    Just have a VS engine on the stand preparing it for installation.
    Whilst changing the front crank seal I found the crankshaft has a tight spot when number 5 cylinder is at TDC.
    It feels like it is touching something soft, almost like a lump of rubber, as the piston hits TDC and when I force it over TDC it is easy to turn until next TDC.
    So, it is independent of whether intake or exhaust stroke.
    Any ideas?
    Cheers, Al
    Oct 2011
    Most likely the piston is going to the top and compressing the air so its harder to push it… Sounds like there is nothing to worry about so dont stress
    IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
    MY DAILY NOW WITH ECOTEC CONVERSION
    http://forums.justcommodores.com.au/...ml#post2145177
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Is the resistance felt with the sparkplug in or out?....were the piston bores lubed after pistons reinstalled?.. I'd want to know exactly why this is happening especially after spending a lot of time/money on doing an engine up.
  1. tar spots on paintwork
    By scottssv10 in forum Car Care Products
    Last Post: 25-12-2011, 04:54 PM
  2. vx flat spots
    By vxcommie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2011, 04:43 PM
  3. Sub spots.
    By Robertsbrock in forum Car Audio
    Last Post: 19-01-2011, 08:17 PM
  4. Cleaning Those Tight Little Spots And Carpet
    By hulmy29 in forum Car Care Products
    Last Post: 17-12-2009, 11:51 AM
  5. What are these white spots everywhere?
    By patullose in forum General
    Last Post: 16-12-2005, 07:45 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
