Results 1 to 13 of 13
Thread: t5 5 speed into 96 vs acclaim
    VS Acclaim
    Dec 2010
    wondai
    Default t5 5 speed into 96 vs acclaim
    I've just brought a t5 5 speed that was in a vr berlina and I want to bolt it into my 96 vs acclaim s1, it has irs but not sure if I can run the auto diff on a 5 speed and not sure on what else I'll have change
    Oct 2011
    Hmmm was it getrag in the first place??? If so then you will almost haft to do a whole another conversion because you will need to change stuff like pedal box,tailshaft,clutch cable etc also wiring also yes you can put a 5speed against the auto diff
    IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
    MY DAILY NOW WITH ECOTEC CONVERSION
    http://forums.justcommodores.com.au/...ml#post2145177
    VS Acclaim
    Dec 2010
    wondai
    Oct 2011
    Quote Originally Posted by aussietrucker82 View Post
    No it's a auto at the moment with a bt1 chip
    Well if its auto you will need a while conversion kit.. Which is Gearbox (which you already have),flywheel and manual flywheel bolts,clutch,spigot bush,pedal box,tailshaft,centre console,clutch cable, i think thats it.
    VS Acclaim
    Dec 2010
    wondai
    i have all that but i don't have the vs flywheel but not sure if the vr 1 will bolt on
    Oct 2011
    Yes VR flywheel will bolt on but you will haft to get it balanced. i just did this to mine but stupidly didnt get it balanced and now the engine vibrates when i rev it. its ok at idle but anywhere between 2000 3500rpm it shakes a bit so make sure you get it balanced
    Vs evecutive s1
    Nov 2011
    Bayside
    VS Acclaim
    Oct 2011
    Crystal Brook
    I'm about to do this exact thing. Where and how do I get the flywheel balanced? because auto doesn't have a flex plate to balance it to does it? So what do i get it balanced to? i have a getrag flex plate if that helps... and will any vn- vs manual starter work? Sorry for hijacking thread..
    Oct 2011
    Quote Originally Posted by Linzi View Post
    Yes the flexplate is the auto flywheel.. You will haft to get it mirror balanced (i think they call it) to suit the auto flex plate. You cant machine a dual mass flywheel tho so you could only do it if your using a solid flywheel.. Yes any manual starter from vn vs will work. Im using my VR starter on my ecotec. also you can get it balanced at a clutch place
    VS Acclaim
    Oct 2011
    Crystal Brook
    So I can take my auto flywheel and manual flywheel into a clutch place and ask them to mirror balance the manual one to the auto one?
    Oct 2011
    Yeh im pretty sure thats how it works...
    LS1 VT SS
    Sep 2004
    Mandurah WA
    Thats exactly how it works. Take your clutch/pressure plate in as well when getting it balanced.
    1999 LS1 VT SS
    1991 VN LS1 Conversion underway
    VS Acclaim
    Oct 2011
    Crystal Brook
    Sweet, thanks for that fella's, was starting to get worried about finding a vs flywheel. I'll give the brake and clutch place a call on Monday
    You can have your thread back now Aussietrucker, sorry mate!
  1. top speed of each gear (1987 vl sl 5 speed manual)
    By harry1994 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-04-2011, 12:30 PM
  2. [QLD] FS: VR Acclaim LS1 6 speed manual
    By combatantsomeone in forum Vehicles For Sale
    Last Post: 03-09-2010, 12:55 PM
  3. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 05:39 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 10:12 PM
  5. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 10:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
