Hi All,
Both my Odometer & Trip Meter stopped working on the weekend.
Went for a Cruise out to Northam (110 kms east of Perth) and the road out there can get pretty bumpy at times. Not sure if something has rattled loose or broken.
Does anyone have any ideas on what I should be looking for when I pull the cluster out ?
Thanks.
Does the speedo still work?
Doing a search would of given you some answers...
Broken Odometer
if your speedo is still working, but your odo/trip doesnt work, i believe it will be the sun cog in the speedo cluster insert. over time the teeth become brittle and can snap off and it only takes one tooth to be snapped off before it will stop working
The search function: try it people it actually works. heres proof
http://forums.justcommodores.com.au/vr-vs-holden-commodore-1993-1997/190851-thanks-heaps.html
Vr/Vs Commodore code checking
http://forums.justcommodores.com.au/...s-revised.html
thanks james, as i just upgraded my dash, i never got the chance to take a pic of the broken gear cog
U can either spend 2 bucks on a cog or you can buy my cluster for 50 bucks
well i dont know where you live, but it would have cost me 50 to get the cog so i went and upgraded my dash. best thing i ever did and havent regretted it for a second. not really that hard to do and if you use the correct harness unlike me then it will be even easier
yes and i know that to heath, my comment was referred to the op. couldnt be stuffed checking his bio
if your in wa like your bio says, jump on the quokka online and have a look
Thanks all for your input.
I ordered the two cog set James39 showed in post #14 yesterday. $15 on ebay. Didn't see the second one James posted above when looking through ebay yesterday. Oh well, should do the job.
Hopefully it will be here next week.
And Ghost, thanks for the offer but I'll give this a shot.
when you go to change the cog, you dont need to take the needle and face off to do it. all you need to do is undo the bolts/nuts that hold the middle cluster in and once out carefully undo the 2 phillips head screws that hold the odometer motor in. easiest and quickest.
Yes i have james. i actually did it for a member on here and posted it over to him. i was using information that was provided to me by members on here when i was tossing up whether to replace cog or upgrade to lvl 3 dash. obviously the person who gave me the name of the first cog as a sun gear doesnt know what theyre talking bout. but using my description you have managed to figure out which one i was talking about so i would assume others would as well lol
Instructions will be with it anyway no worries
So have now fixed this little problem. Thanks again for all your input guys.
