Results 1 to 4 of 4
Thread: Downshift issues
    someguy360's Avatar
    someguy360 is offline GWJ Vehicle Enhancements
    94' VR Stato V8 (Weekender) - 06' Holden Combo Van
    Jan 2011
    Small boring town in SA
    Default Downshift issues
    Hi Guys.
    I have had an issue develop in my VS for the last few weeks, wondering if anyone has any ideas.
    Relevant info on the car: V6, Full exhaust, Tune, Corvette servo, 3.45 Diff.
    What used to happen when I wanted to downshift is simply tap the accelerator, the car would drop down a gear and take off.....now I have to put my foot almost 3/4 of the way down before it even considers downshifting.
    I have serviced the trans, checked the error codes (only had error 97 which is the charcoal canister solenoid which has been faulty for ages), checked and put a spare TPS on, cleaned MAF, checked for blockages in the intake and also checked the tension on the accelerator cable and still no luck.
    Anyone got any ideas?
    Only other thing I can thing of is that the car was tuned before the 3.45's went in, but it seemed ok for a little while
    Thanks
    Forever in the garage
    New Weekend Cruiser
    Old Weekend Cruiser
    "General Motors spends millions of dollars per year in research & development..........You think you can do better in your backyard.......good luck with that."
    vs commodore
    Oct 2009
    Tamworth NSW
    The speed sensor ratio needs to be adjusted in the tune to suit the lower diff ratio, otherwise the auto wont shift correctly and the speedo will read wrong.. When I was doing tunes for people, I did a few for blokes who had a lower diff ratio, and when I tested the tunes in my car with the standard diff ratio, it stuffed up the shifts etc and it needed to be reved a lot harder to shift up or to kick down etc
    someguy360's Avatar
    Jan 2011
    Thanks Brett
    Have sent Steve from MACE a PM to see if he can alter the tune for me (tune was by MACE)
    New Weekend Cruiser
    Old Weekend Cruiser
    vs commodore
    Oct 2009
    Tamworth NSW
    No worries, let us know how you go with it.
  1. Heel-Toe vs Rev Matching On Downshift
    By the_trademarc in forum General
    Last Post: 14-11-2011, 08:27 AM
  2. SIDI SV6 SERIES I Auto - Downshift rev-limiter
    By curious2010 in forum VE Holden Commodore (2006 - 2013)
    Last Post: 08-11-2010, 09:31 PM
  3. VS manual Getrag Crunchs on downshift into second...
    By vsspack in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2010, 05:06 PM
  4. No manual downshift :(
    By KnobMuffin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2010, 04:28 PM
  5. VL Auto Transmission - Rough downshift from Overdrive
    By grazm in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-08-2008, 11:31 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
