Results 1 to 5 of 5
Thread: Dumb question VS diff needs to be asked
    Toyota Landcruiser
    Oct 2005
    Central QLD
    Default Dumb question VS diff needs to be asked
    Diff, Wagon, non IRS back axle, how much oil does the housing take it's getting noisy on drive and have just spent a fortune on other parts for it.
    I know to get a manual would be simple, but cash is low.
    Having used Nulon in the landcruiser gearbox and finding the stuff nothing short of brilliant, I have to ask how much oil the housing takes ?
    The rubber plug filler is this a sight hole also or just a filler, and is there a simple way to remove the plug or is it just as easy to fill it from the drain hole.
    What is a newbie worth and what ratios are available, or is their just the one ?
    rattattack1313 Guest
    Cool
    Just fill to the bottom of the filler hole.........can't help you with the rest , sorry.....
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Thumbs up
    I'd did mine a few months ago. Just unscrewed the whole thing and droped the old oil into a drain pan. Give it a bit of a clean and check everything it alright in there. New gasket and reassemble. Pull out the rubber filler and refill from there. I use Castol LSX90 (if I remember correctly). You may want to use gasket goo or similar if you pull the housing off for a more secure seal than a paper gasket. Hope this helps
    Toyota Landcruiser
    Oct 2005
    Central QLD
    Thanks fellas.
  1. Has your question been asked before?
    By Tasmaniak in forum Car Audio
    Last Post: 10-05-2010, 10:25 AM
  2. dumb things asked 2 do
    By bangers in forum The Pub
    Last Post: 08-03-2006, 09:52 PM
  3. Dumb question about IRS
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 06:10 PM
  4. Asking a Dumb Question
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2005, 12:40 PM
