whats the standard size on vs v8 or even the vs v6 are they the same size?
VS V8 - 65mm unless i'm incorrect, VS V6 is a out-of-round 58mm and 60mm.
so will getting a 70mm one make much difference?
i wouldnt bother, you wouldn't notice much at all. I know these are about 10 times more expensive but get a twin throttlebody setup, then there will be difference.
Some people say less talk more action, i say more torque less traction.
yeah the inlet passage in the plenum is the big restriction, you'll need to massage that first or go twin throttle body on the V6
do u know if u can replace a v6 throttle body with on from a v8? i got a v8 one sitting here but all the sensors etc are in different spots so im not sure if it will bolt on or not? any1 done this b4 or know if its possible?
