my knock sensor on my vs clubsport 5l was stuffed had to get it fixed when they pulled it out some coolent came out is it ment to does the water run near there?
Actually when you drain the cooling system, if you want to get every last bit of coolant out you have to remove the knock sensors to get the last 3 litres or so out of the block
