Results 1 to 7 of 7
Thread: How can I trigger the doors to lock/unlock?
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Default How can I trigger the doors to lock/unlock?
    Hi all I am trying to install an alarm/immobiliser to my VS and am struggling to get the alarm to successfully lock and unlock the doors. The alarm is negative switching. If relays are required I have a couple handy.
    Anyone done this before? Know which wires I need to either ground or tag with 12V?
    Any help appreciated
    Thanks
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    2004 VY2 SV8 A4
    Jun 2005
    Come on people you can't tell me none of you have installed your own alarm before??
    ford
    May 2005
    in a ford
    VS Exec
    Mar 2005
    Quote Originally Posted by shaggerz
    Installed alarms before but I bailed on my VS because the remote built into the key is already imobiliser / keyless entry and preferred to keep it in the key.
    So for alarm I just got an alarm upgrade for the existing imobiliser keyless entry which cost me $300.00 installed.
    I think most people would go for that option because they dont have to worry about an extra key fob.
    VRII Acclaim
    Jul 2005
    Doesnt your car already have the central locking? Cant you just use those relays?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Here are the wiring connections for my vr for my alarm upgrade.I used a mongoose alarm upgrade kit.VS's use a drivers door only as one function on the key so it has to be wired a bit different
    Of course the control of the locks is by the BCM and the request signals are earths and the controls are two wires (brown orange and brown/red)that have a polarity change ( when 1 wire is 12v the other is negative and vise versa) to either lock or unlock the door motors.The drivers door must have its own pair of wires to make the unlock it only function.
    Attached Thumbnails Attached Thumbnails How can I trigger the doors to lock/unlock?-unlock.jpg
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    2004 VY2 SV8 A4
    Jun 2005
    markovr that is just the information I needed!
    OK so the brown/orange and brown/red wires are the important ones. Looks from that diagram like your alarm has negative triggers. My alarm also has negative triggers. Should I be able to simply connect these triggers to those wires? What is the state of each wire when at rest? (neither locking nor unlocking)
    ie.
    Brown/Red Brown/Orange
    Locking: +12V Ground
    Unlocking: Ground +12V
    At Rest: ??? ???
    If I could figure this out I know I could make it work for sure!
    Thanks for the help
  1. Other Doors Unlock When Drivers Door is Opened
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 09:55 AM
  2. Vp passenger doors wont unlock
    By RobertAH in forum Electrical Wiring / Questions
    Last Post: 28-07-2006, 05:06 PM
  3. Need to lock then unlock to start car
    By Prophesier in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2006, 11:05 AM
  4. Torque converter lock unlock
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2005, 02:29 PM
  5. Unlock/Lock Blinker flash
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2005, 10:39 PM
