bonnet wont open
KhaosInc
Donating Member
40
Bris South
VR Calais V8 M5
i have a vr berlina and the bonnet release inside wont do anything but clunk when you pull it then clunk again when you let go and isnt releasing the bonnet so the secondary release can be activated.... i can't see how to get in to release it from outside.
does anyone know how to? cause id like to be able to open it :b:
thanks for any help.
Charg'd
in a ford
ford
you need two people, one to push down on the front of the bonnet and someone to pull the bonnet release
jafo
lurker since 2003
59
adelaide
1999 wh statesman
if you get under the car at the front with a decent size screwdriver (flatblade) you can manipulate the spring that holds the striker just shine a torch up there and you will see .
i had the same problem with my vs after having the front end fixed
KhaosInc
Donating Member
40
Bris South
VR Calais V8 M5
they both answered it... thanks... i tried the push down first didnt work after many attempts.... screwdriver fixed it... but i need to push down on it to open it... i know there are answers to that problem elsewhere on here.
thanks.
kopper69
37
VRII Acclaim
Im having the same problem, thinkin about replacing the spring. Already tried wd-40 and silicon spray, they just aint working for me anymore.
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
yea i recently had to get mine replaced, just grab one from the wreckers rpetty cheap
Stewart1000
work done by ME
34
vic
www.justcommodores.com.au
VL twin turbo. VN5L. old jeep, **** mondeo.
yeah same problem on my mates vn, you have to push down when someone pulls the leaver, would make it harder for a thief to steal your battery tho.
started to happened out of nowhere too
jafo
lurker since 2003
59
adelaide
1999 wh statesman
to make the bonnet close and open set the striker spring to the correct length from memory its 50mm dont quote me on that been a long time since i did mine.
-------- plate
- - - - - spring
-------- plate
\ / striker tip
michaelw
Donating Member
Newcastle NSW
VX S2
Not bad. According to mr Gregory (for the VN at least) the magic number 52mm from plate to plate.
Mike
