Code 31 - Anti-theft deterent signal missing
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
hey people just asking for your advice,
i ran the diagnostic check and returned codes 12 and 31
i read my book and it reackons its the antitheft deterent signal is missing, but i had a look when i did it the second time and its flashing normally? should i worry about this?
kopper69
VRII Acclaim
Just pop your bonnet and go to the fuse box near the battery terminal. Take off the black cover and remove the 20A fuse called 'engine'. Leave it out for about 10 seconds and put it back together. This will reset the engine fault codes. Check your fault codes again in a week and again in a month. If it comes up again then worry bout it. Does the little red light flash in your car?
fitzy2005
VY S2 Berlina
kopper69} Does the little red light flash in your car?[/QUOTE said:
yep, ok ill take the fuse out and check in about a week, let you know, cheers
ok cleaered code, will wait a week or 2
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
it indicates the ignition has been on & the key didnt disarm the theft deterrent.
normally means the key is on its way out.
Rob
fitzy2005
VY S2 Berlina
Rob
ok cheers, i just got a new ehad thing 2mths ago, ill get it checked out
thanks
VB Owner
VB and VX Berlina
I know this thread is old and i was searching. Could also be the slip ring. Mine has errant starts. Brand new key and Fob
