have you got a pod or an air box?
recently i put a pod in my mates vt and i noticed that he could run a tube down to his left side bumber (right near the rim) to get cold air in i wanted some ideas where to run a tube on my vs
i have taking the old air box out and put a pod in
well you can run pvc pipe to the pod but its better with the airbox and performance panel filter so it actually sucks the air instead of lightly blowing on the pod there is enough room to come up between the radiator and the engine or if you dont mind puttin a hole in your wheel arch come up through there but you'll have to check legalities on cutting a hole, might be a defect im not sure
put your old box back in to make it look stock then cut a hole straight through the box and the metal below and run the pipe from inside the box to the pod at the front
result a stock looking cai
nice work thats what i was tring to say but i diddnt think of the pod on the frontOriginally Posted by HDT_aero
ill try running the pipe in between the radiator and engine ill see if i get a bit more cold air suction thanks
