+ Reply to Thread
Results 1 to 4 of 4
Thread: strut braces
    VR 5.0
    Jun 2005
    QLD
    Default strut braces
    whats the diff between mid and rear mounted struts?
    statement's Avatar
    statement is offline reaching new limits statement Executive
    VY/VZ Calais/Tonner
    Jun 2004
    north but not to north
    r you talking as mid an rear mount in the engine bay? if so the difference would depend on your type of engine.
    the rear mounted type would suit engines that have high intake manifolds i.e groug A, an the brace would go around the back
    the mid mounted type would go across the engine
    here are some samples below.
    Attached Thumbnails Attached Thumbnails strut braces-9a_1_b.jpg   strut braces-photos_commodore_vortech.jpg
    VR 5.0
    Jun 2005
    QLD
    ah cool makes sense i got nothing that would get in the way of mid mount do you know if its worthwhile and do they just bolt right on?
    thanks
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    standard wise they would only benifit the look of your engine bay , but once you start changing your suspension i.e lower shocks, stiffer springs and maybe bigger sway bars then the strut brace will really help with cornering as it stops the two towers from flexing which helps keep the susupension setting right i.e castor, camber and toe.
    as for installing one it really easy an looks the goods
    in life some people need a little guidance, others just need a good kick
+ Reply to Thread
  1. strut braces
    By VROCIOUS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 06:22 AM
  2. strut?
    By harro_VR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 04:48 PM
  3. VZ strut braces
    By dan-0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-12-2006, 10:57 AM
  4. Strut braces
    By fullaaa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2006, 10:07 AM
  5. strut braces
    By Troy711 in forum General
    Last Post: 09-04-2006, 09:07 AM
