Results 1 to 3 of 3
Thread: V8 Vs Auto problems
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Default V8 Vs Auto problems
    Hi All
    My transmission has just started playing up in my VS V8 Auto, just seeing if anybody had any ideas.
    If I take off in Drive, it starts in 1st gear, then just dumps it into Drive, then flicks it back to 1st cause it is about to stall, then slam into Drive again.
    1,2 and 3 seem to work fine, although it feels as if something is holding it back in those gears.
    Any ideas welcome.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do a code check Checking error codes VR/VS (Revised)
    and then check fluid level in the trans.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Quote Originally Posted by hako View Post
    Oil levels OK. Error code 72 - Vehicle speed sensor intermitment. I guess I know where to start to look.
  1. vs auto problems
    By mojododo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2010, 05:19 PM
  2. vs auto problems
    By Mattrob in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2009, 05:30 PM
  3. VZ V6 auto problems
    By paroharo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-05-2009, 05:50 PM
  4. Auto Problems
    By VP5LtrCalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2005, 03:05 PM
  5. VS V6 Auto problems
    By random in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2005, 09:09 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
