drowning vs commie
J
jfallon
Guest
drowning VS commodore
i have a 95 vs commie that i have spent a bit on including putting a vx motor in to this thing. after a down pour the other night the following morning i had 3 inches of water in the drivers footwell as well as the passanger front and driver rear footwells as well. i have removed the carpet and fllor insulation and seats and put a hose on it to find water literally pisses in the firewall up behind all the air con. cannot get at it to see where it's coming from but it's not the air con it's self by what i can tell as it's to much water coming in. any help would be appreciated as all carpets are water logged and tomorrow the holden guys can get it back to sort out but if any one has had this problem would love to hear about it.
thanks heaps in advance
justin :cry:
R
rattattack1313
Guest
Open the bonnet & get all the leaves etc out of the corners , if there is any....is the usual suspect, mate........ :thumbsup:
J
jfallon
Guest
yeah i tried all that vaccumed it throughly but still leaks like a siv any other thoughts
kopper69
37
VRII Acclaim
Does it only come out after you have had the air con running?
J
jfallon
Guest
no it's not the air con but seems to be coming through the firewall where the air con pipes come through. tried silicone on this but hasn't stopped completely but has made a difference
