Results 1 to 5 of 5
Thread: Where is the Aircon escape hole underneath
    Bob40 Guest
    Wink Where is the Aircon escape hole underneath
    I am hoping someone can explain to me where to locate the Aircon drain hole
    for my VR commodore SL sedan 1993/4 from the underneath.
    It has built up water from shutting off and the water is leaking into the drivers feet.
    If there is a site anyone knows that I can see a photo of same
    would be great help
    Also if there is a solution / part replacement to stop the valve whole from closing, would be great.
    tks
    Bill
    94 VR Exec
    Nov 2005
    Lightbulb Re Aircon drain
    G'day Bob40,
    If you look on the left side of the heater box (in the passenger side footwell where the console finishes) you should see a black rubber plug about 2CM in diameter.
    Get a bucket and sponge to catch the water and, using your fingers or a set of pliers, gently pull back the top edge of the plug. Depending on how blocked up it is, there may be a fair bit of water leakage so be ready with the sponge and just keep re-seating the plug until the torrent subsides!
    When ready, pull out the plug completely and you can access the drain hole from above. Mine was full of rotting leaf matter and sludge. Use a long thin cable tie to poke down the drain hole and you should be good to go. You should also be able to clean any muck out of the area with a chux cloth.
    I haven't looked to see if there is a corresponding drain on the driver's side. This method works for my VR Exec and saves you having to crawl under the car. It's important to keep the inlets under the bonnet clear of debris as this is the stuff that eventually causes the blockages as it breaks down and finds its way down into the heater system.
    Hope this helps
    VRII Acclaim
    Jul 2005
    If you have a Gregorys manual its on page 290. If you dont have a manual get one, you will use it and it will save you $. Basically put the front of the vechicle on stands and look just near the start of the transmission. There is a small drain hole that you just need to poke. Wasps and mud get stuck in there and block it up.
    grazza_vr Guest
    had same prob, cost like $5 for a machanic to do it, saves u lookn, waste'n time...
    VRII Acclaim
    Jul 2005
    grazza_vr you lazy ass I cant believe you paid someone. "cost like $5 for a machanic to do it, saves u lookn, waste'n time" It takes about 5 minutes and you dont have to muck around getting mechanic. You could have it done in a fraction of the time it takes to drive to the mechanic. Plus you know its done right and you can fix it if it happens again.
  1. aircon water only comin from 1 drain hole under car
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2008, 12:47 AM
  2. IRS statesman clunking underneath
    By yotaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2007, 08:39 PM
  3. Replies: 18
    Last Post: 15-12-2007, 04:44 PM
  4. Rattle from Ls1 rear/underneath
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-11-2007, 09:22 PM
  5. Rubbers underneath Bonnet
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 07:14 AM
