Results 1 to 14 of 14
Thread: Shudder under acceleration
    mr_v8 Guest
    Default Shudder under acceleration
    Hi guys,
    I have just purchased a VR v6 S1 and when I am accelerating, there is a shudder from the rear end...
    I have been told that a boot (I think it goes somewhere near the drive shaft and diff ?) can cause this if it is old.
    Any ideas ?
    Cheers.
    deathsminion's Avatar
    deathsminion is offline Chrgd,Coold,Twinthrot'in
    GT42R forced JZA80 Supra and VT Wagon
    Oct 2004
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    tailshaft centre bearing
    tailshaft unis
    engine mounts
    gearbox mount
    trans oil level
    first off check you have the same size rims all round
    im not admiring your car im looking in disgust
    mr_v8 Guest
    Yeah, all the wheels are same size...
    The shudder only happens under hard acceleration, if that helps and is certainly coming from the rear.
    VE SV6 2009
    Jun 2005
    Liverpool
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    VS SSBodyKit
    Sep 2005
    when i bought my VR there was a shudder especially in first and second when u put your boot down.
    the car yard fitted a new tailshaft and now theres no shudder.
    The tail and driveshaft was not alligned properly.
    mr_v8 Guest
    I am leaning towards the tail shaft having some sort of drama... but I guess I'll see what the mechanic says...
    MaXiLeeCH's Avatar
    MaXiLeeCH is offline irc.WorldIRC.org boss
    1995 VR Series II Berlina
    Jun 2005
    It's the centre bearing in the tail shaft..... Get it replaced and all should be fine.
    FWIW, if you get a shudder on slow down, its usually the centre bearing dying too.
    simple to fix, if you have some experience.
    Hope this helps
    MaXiLeeCH
    Keeper of his faith, Lord of his ring & all 'round good guy.
    VP V6 BT1,VR 5.0l statesman
    Nov 2004
    sydney
    hi,
    i've got a 5.0L VR statesman and the centre bearing has had it! i was quoted $170 to fix it and told that it was pressed in?? are they hard to change at home???
    mr_v8 Guest
    thanx heaps for all of your repsonses... its off the mechanic tomorrow morning, so I guess we'll see what they reckon (or how good they actually are - the car yards bloke)....
    will update once fixed
    VS Acclaim
    Apr 2004
    Get your tyres alligned and balenced. I had the same problem and it turned out that my rear tyres were out a few degrees which caused the car to shake under acceleration. Its worth looking into. BTW are your rear tyres very worn as my problem was actually found as i was getting a wheel change-over cause my rears were bald
    mr_v8 Guest
    Hi everyone... Just wanting to let you know that one of my uni's was worn, so the mechanic changed it... volia ! no more shudder...
    BTW, tyres are in excellent condition
    Thank you to all that shed some light on this for me !
    matt69 Guest
    i had a centre bearing done for $100 dollars fitted. used to make a hell of a noise with four people in the car lol.
  1. VN has no acceleration
    By snowbeast in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2010, 05:51 PM
  2. Acceleration Shudder
    By Nick H in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2006, 05:06 PM
  3. smoother acceleration???
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2005, 05:59 AM
  4. bad acceleration
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2005, 04:23 PM
  5. Acceleration Shudder
    By joem in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2004, 02:50 PM
