+ Reply to Thread
Results 1 to 23 of 23
Thread: VS Statesman
    VLishes's Avatar
    VLishes is offline BaZMeG VLishes has disabled reputation
    VS Calais SII
    Jul 2004
    Default VS Statesman
    Heya, I'm thinking of getting a VS Statesman, just have a couple of things I need to found out before I purchase one;
    Is it fairly straight forwarding converting a from auto to manual?
    also
    Can you chuck 17x8's on? on the placard it's states 15" wheels, now vicroads says on their website:
    The width of any replacement rim must not be;
    - more then 25mm greater then that the widest wheel specified by the vehicle manufacturer for that model or vehicle.
    The overall diameter of any replacement rin and tyre must not be;
    - more then 15mm greater then the largest diameter tyre specified by the car manufacturer for that model or vehicle series.
    So that means that I can't put on some VZ Calais wheels. Tho the SIII comes with 16" and on the VS Calais placard shows 16", now technically I know you can put these on the car but for insurance reasons I can't, plus it does make the car unroadworthy.
    Any suggestions?
    '96 VS ACCLAIM (duel fuel)
    Sep 2005
    if your after a VS statesman 3.8 on gas, i might have someone who is willing to sell it...
    Jun 2005
    E Subs, Melb
    Cool
    Quote Originally Posted by VLishes
    Yes you can, because it's the rim and tyre combination that is important. ie if you increase the rim size by more than 15mm you need to put on low profile tyres so that the increase in the overall outer diameter of the tyre does not exceed 15mm.
    P.S Do a search on manual conversions. It's possible (anything is...) but how easy it will be would be dependent on your mechanical ability
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    Quote Originally Posted by futronix
    Hrmm gas, not really a fan of it, how much is the VS?
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    Quote Originally Posted by semmi
    I probably should refrase, I ment $ wise, if I get a someone to do it, would it cost around the same as converting a normal VS? They are probably mechanicaly the same but Statesmans have more electricals in it, I don't want to spend half the cars value on converting it to a manual, then again I don't really like auto either.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    well converting to a manual would be a hell of alot easier with a whole engine and box...because its not as easy as just chuckin a new manual box in,you'll need to replace a tonne of stuff.
    basically its gunna cost you quite a bit to do,so i hope your prepared for some hard work and lots of money.you might be better off searching (as hard as they are to find) for a factory manual.
    StatOmaN's Avatar
    StatOmaN is offline Custom Title StatOmaN Executive
    Vr Statesman
    Aug 2005
    Bangalow
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    Quote Originally Posted by StatOmaN
    dont think they made ststos in manuals, all autos bugger it
    Yeah, thats what I thought, generally the old folk who would buy these cars are too lazy to drive manual, hrmm whats this world coming too.
    2x VS
    Jul 2005
    I have seen VS Berlina's advertised with 5 speed's before so I'd say that there should be parts available to do the conversion...
    I was thinking of doing the same thing to a Calais...and I posted to a few wreckers who were quoting around $1700 - $2500 supplied and fitted...
    I think you'll have most of the hassles with the tailshaft...
    sorry that I cant be much more help.
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    VS Stato SII L67 S/C V6
    Apr 2004
    all statos were auto out of the factory
    the stato has a longer wheelbase than the sedan, so be prepared for messing around with tailshafts
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    Hrmm ok, so what you guys think of the Statesman? Currently I just got one tested at a RACV place, it's a 98Nov-VSIII, 178k but it's been serviced every 10k~, might offer him 8ish due to high k's, anyways, what are they like on fuel? mainly city? parts and servicing expensive on these?
    Sphinx's Avatar
    Sphinx is offline O.G. Sphinx Berlina
    VX Calais II LS1
    Aug 2005
    Pakky
    I've got a 95 VS 5 litre Stato with 162 thou on it and she can be a bit thirsty. Highway driving is about 9.8 litres per hundred and around town, well, its anywhere between 12.5 and 16 litres depending on how you drive it..
    The Calais
    Sleeper Club
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    Mine's a 1996 VSII 5.0 and 168,000 on it. Doing heaps of small trips with stop-start traffic in the city a few years ago I remember being at 22 Litres/100km and that was going easy on the right foot. If you're a leadfoot driver be prepared for bad fuel economy. Now with a lot more highway driving and some city driving it's at 13.2 L/100km (averaging 52 km/hr) but still with a granny foot.
    Parts are relatively cheap because the standard V8 was mechanically identical from 1988 to 1998 so with that economy of scale you see good pricing. The other bonus is that unlike the V6 there's no CAS to worry about failing on you!! As for servicing, it depends on where you go for it but expect similar pricing to a V6.
    The only area that may get expensive is with the CD stacker, check yours works properly before you buy the car (think upwards of $700 for a new one). Check the climate control operation as well especially under full vacuum loading because vacuum leaks can be a pain to find.
    VL executive
    Aug 2004
    Quote Originally Posted by haloeight
    I'm pretty sure that the ute has the same wheelbase, although don't quote me so you should be able to get the gear out of one of them as lots of the utes were manual...
  15. #15
    Apr 2004
    the ute is the same wheelbase, but different axle
    the vs stato has IRS, ute is live axle
  16. #16
    Apr 2004
    also do yourself a favour and check out the supercharged statos
    almost the same power, and a lot better acceleration than the v8, and a lot less thirsty
    i average 7-9l/100k in the city
  17. #17
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    the statos where based on a wagon wheel base,so if you got a manual berlina wagon with irs you'd be sweet to transplant.
  18. #18
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    thanks guys for the input.
    The Eurovox stacker looks similar to my old Blaupunkt stacker, tho the connection looks the same as my new stacker I got, well the DIN plug looks similar.
    I received my racv report back today, there is a couple of things I need to check out, the main problems are;
    Oil Leak (Engine & Transmission)
    Pump & Hose leak (P/steering)
    Windscreen needs sand blasting
    Rear tyres are low and spare needs replacing (I would like to get VZ Calais wheels)
    LHS headlight has crack and LHS foglamp lens is cracked (has hole)
    Exhaust needs attention, which I was going to replace with a sports exhaust.
    There is other minor problems as well, maybe offer 8k, tho I didn't really want to spend money on a car I just bought for a while. I mean it has 178k so there is wear and tear and I thought for a highway car it should be fine.
  19. #19
    Jun 2005
    E Subs, Melb
    i have vz calais wheels on my car, i noticed you're in melb... so if you're looking for a set you can get them from wheelking in moorabbin, i think i paid about $1480 which included new low profile tyres, fitting and balancing.
    they have a website too: www.wheelking.com.au
  20. #20
    VLishes's Avatar
    VS Calais SII
    Jul 2004
    Thanks for the site, I might just buy the rims from there, place in Reservoir sell cheap 2nd hand tyres with 90-95%~ tread. Do you have a pic of your car? would like to see what the vr looks like with these wheels.
  21. #21
    Jun 2005
    E Subs, Melb
    i am at work at the moment so the only pic i can give you is one that has already been posted here - this is the link:
    http://forums.justcommodores.com.au/...629#post145629
  22. #22
    VS Executive Series II 1997
    Aug 2005
    Gold Coast
    semmi, you have the same colour as me and done everything i want to do my car
  23. #23
    Jun 2005
    E Subs, Melb
    you've got good taste mate!
+ Reply to Thread
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2010, 09:13 PM
  2. vq statesman
    By bassdj5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2008, 07:44 AM
  3. s/c vs Statesman or Vs v8 Statesman???
    By younggun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 08:31 AM
  4. FS VQ S2 Statesman
    By wantdvq in forum Vehicles For Sale
    Last Post: 17-10-2006, 10:48 PM
  5. vq statesman
    By vq rat in forum Parts And Other Items For Sale
    Last Post: 08-05-2006, 07:24 PM
