Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: whos put a pod in a VS?
    jay123 Guest
    Default whos put a pod in a VS?
    whos put a pod in a VS .... ?
    i got a vs series 2 and wanna know what to do with the sensor actually in the box
    my mate just got a VU ute with a huge pob on it he kinda had a custom bracket from the pod to the intake tube and on this braket they relokated the sensor , can you buy these or do you have to make them custom????
    hope some one can help, and yes i know about the hot air and all that but i still want a pod!!
    Z()LTAN Guest
    easy to do yourself, get some like 1-2mm aliminium sheet and cut a strip of it like 2 inches wide and wrap it around a part of ur intake wrap it around and onlt otself a bit then drill a hole in the end wraped over thenmake it nice and tight and drill through that hole, through the aliminum underneath and into the intake pipe, makesure the hole is bigenough for the sensor to fit in and slide it in there and clip it in place, the sensor will work as a pin to hold the aliminum in place and the sensor itself, but realy y do u want a pod, cai and pad fighflow K&N so much better i rekon, thats what i have
    jay123 Guest
    wont air excape throught the join but? sounds dodgy.. na want a pod . gonna keep my cai on but so it still gets some of the cold stuff? have you put a pod on?
    Z()LTAN Guest
    i had pod b4 and did jack shit, u put silicone int he hole first and push it through and clean up the excess, thats what i did and never had a problem
    jay123 Guest
    yeh i guess that sounds like the simplest option. you know of anyother ways of doing it or heard of a pre made braket?
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    ive got a pod on mine.i didnt bother riggin up anything for the sensor,i simply put in inside the pod,it works a treat and ive never had any troubles.
    Z()LTAN Guest
    jay123 Guest
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    no.literally put it inside....
    free up some slack with the wires to the sensor then place it inside at the bottom of the pod,just past the lip where it drops off to the actual filtering surface.
    i put some electrical tape around the intake pipe to hold the wiring at the desired length then put the pod into the intake pipe as normal.
    too easy,as i said,works a treat
    jay123 Guest
    what size was the base to fit into the intake tube. did it still fit on ok with the wire going throughaswell
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    umm,i dunno mate.
    i just had a k&n pod which i bought for my vn calais and swapped it onto the vs when i was sellin the calais.
    it fits fine with the wire there,ive noticed when i take it off for cleaning that the wire has made a small indentation into the rubber of the pod base,so its perfectly sealed.
    jay123 Guest
    VS Exec SII 3.8 V6
    Nov 2005
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    i hear pods and cold air intakes are a waste of time and money, make no difference on the dyno. My mate in whyalla SA has the VZ SS and i got the SV6. He put on the SS induction airintake with the pod filter and had it dynoed before it was on and after... Guess what. No farking gain. Hes sold it and gone back to factory air box and just runs a K and N. Better off saving your money for a computer remap. My 2 cents.
    Quote Originally Posted by Skitz View Post
    Go ahead with the SS badges,you will reap the benefits.
    I have put SS badges and the kit on my VE Omega and when I go cruising and rev it past the girls.........well what can I say,they have drool running down their face.I chuck a U-turn and they say ''Nice car'' and I say ''It's an SS,jump in''.
  15. #15
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Unless your dyno was travelling at the indicated speed I wouldnt expect much of an increase either.
  16. #16
    Z()LTAN Guest
    lol put a fan infront of the dyno and ull get a diff, thats the point lol, it only works when ur moving, air ram effect....i thought that was obious
  17. #17
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Most of the fans for dynos only push enough air to cool the engine and not represent the actual road speed. While they can give a good indication of nearly all mods there will be a few that wont show like CAI.
  18. #18
    Z()LTAN Guest
    well i can say that my ss inducions cai both makes my engine bay look great and works a dream,
    Attached Thumbnails Attached Thumbnails whos put a pod in a VS?-engine-bay.jpg
  19. #19
    jay123 Guest
  20. #20
    VT
    Apr 2005
    QLD
    i put a pod inside my airbox on my VT, courtesy of a deeper box than the VS, i managed to put in a sizeable filter. *shock, horror* i left the air temp sensor where it is. in the lid of the box. still runs fine, never been an issue.
  21. #21
    anotherstockvs Guest
    im sure other people have said this before but im gonna say it anyway pod filter is the biggest waste of a time especialy when ppl hook it so u can see the pod filter but it will only absorb heat from the engine and u will loose power ur much better then just getin a k&n filter and then hook up a CAI,the only way a pod filter is good if it is enclosed in a airbox with a cai
  22. #22
    Quote Originally Posted by highendrev
    well thats very funny of course it wont make a difference cause ur not gonna get much cold air just sittin on a dyno, a CAI and a K&N filter will make aprrox .2 secs diff to a car on the quater
  23. #23
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
  24. #24
    VT
    Apr 2005
    QLD
    Quote Originally Posted by fitzy2005
    lol cai isnt just for power, its to keep the Air Cold
    cold air=more power? rhetorical question of the month
  25. #25
    mccorncob Guest
    when i put my pod on i just used a length of pvc pipe to join it to the maf, drill a hole in the pvc for the sensor. its pretty tidy my pics on the vr..vs pics
  1. whos that guy?!...
    By belave in forum Jokes/Humour
    Last Post: 27-04-2007, 07:39 PM
  2. Whos in syd?
    By Crimin8 in forum The Pub
    Last Post: 17-12-2006, 10:44 AM
  3. exhaust.. whos done it??
    By hbdvysute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-08-2006, 06:17 PM
  4. Whos Awake???
    By MikeVXSS in forum The Pub
    Last Post: 01-04-2006, 06:27 PM
  5. window tinting whos good at it and whos not
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2005, 10:42 AM
