i would like to hear some opinions
is it worth getting a stage 2 kit in a 5L auto?
at the moment i still get a chirp into second without one, but probably only 2 out of 10 times
A stage 2 will have you chirping, with the possibility of breaking traction completely, depending on rubber and road condition. Stage 2's tend to make your box a bit stronger as well, at the cost of putting more strain on your diff. So if your diff is good, then go for it.
I put a DIY B&M kit in my auto v6... i went from never churping, to churping 6.5/10 times.. plus its good to put kits into your auto if you dont go over the top. (I installed the stage 2)
i have an irs lsd 175 000 k's ya reckon it will be up to it?
If it's still tight, as long as you don't constantly chirp, it should last a fair while.
...so if you don't push it does the tranny change smoothly or do you always get a bit of a jolt thru the gears ?
it also depends on how your kickdown cable is set up and wether or not it has a stally or not......mines still a bit harsh thru the gears and definately chirps sometimes even third on the hot mix because there is no weight in the back end
Originally Posted by vsv8berlinawag
If you drive gently, you won't notice a difference. Less lag on kickback though.
i just put in a stage one cause ive already had enough probelms with tranny and didnt want stage 2 breakin n e thign (what ive heard)
unless i can upgrade it again im pretty happy with teh changing.
what's the co$t of getting a stage 2 kit installed and I guess a stage 1 (if one is made) is pretty lame and a waste of money ? Also does it really make your tranny last longer ?
i was quoted 600 from the guy that rrebuilt my box
and it only cost 1400 to get my auto fully rebuilt the nearest quote i got in bris was 1700
I got a B&M stage 2 DIY for $85
You can do a Stage 2 on the cheap for about $300 including labour. I had mine done properly with booster valves, corvette piston etc. for $700. On WOT it cherps 9/10 times, sometimes on 3/4 throttle. It also depends on road surface/conditions and the amount on rubber on the back. I'm currently running 225/60/15's.
reading a few posts seems its probably worth getting the stage 2.
i put in the stage one for other reasons including money at the time.
question is can i upgrade it from there or do i have to pay for a whole new kit (like will it cost less cause ive got stage one installed?)
thx.
