+ Reply to Thread
Results 1 to 15 of 15
Thread: water disappearing - water pump - how to change?
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default water disappearing - water pump - how to change?
    The vs was running very hot and the engine light came on. Pulled over and waited for dad to come and help.
    No water in the radiator, but the overflow was full.
    Put a heap of water in, and started it up. There was a small trickle of water running off the bottom of the engine. I think it is coming from the waterpump, as there was also a little wisp of steam there before the water went on.
    How can i be sure that it is the waterpump that is dead?
    How can i fix it?
    thanks
    ECOTEC KICKED IN yO!!!!!!
    Lumps of cheese's Avatar
    Lumps of cheese is offline catch us if you can Lumps of cheese ClubSport Lumps of cheese ClubSport
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    water will pretty much pour out around the pump itself.
    They are easy to change, just go to your local auto parts place and pick one up for 80 bucks.
    Just undo main drive belt, you will need a ring/open end spanner or socket, can't remember the size but you will find the nut on one of the pulleys.
    I think there is about 5 bolts, undo them and the pump just comes off, may need to tap it lightly with a hammer to free it.
    Clean off old gasket from the motor, important you do this otherwise it won't seal propley, then just fit your new pump.
    usually only takes about an hour for the job, any questions let me know
    2x VS
    Jul 2005
    You should have let it cool down before filling up with water again...you may cause the radiator to crack from filling it with cold water...
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    May 2004
    darwin
    there was a bit of a wait for the water and it wasn't cold, cold water in containers doesn't happen in darwin!!!
    we'll go for a drive tomorrow in the other car and get a pump me thinks.
    thanks guys
    VR Statesman
    Jan 2004
    Wyee
    a hint, get a peice of chalk and on a wall or on the floor clear of the car draw the pattern for the fanbelt.
    Remove the belt after drawing the pattern
    The rest is bolts outs and bolts in.
    Give the gasket a good smear with grease before you face it on the pump and it will then stick and give a better seal against the pump.
    In hot conditions make sure you run Holden/ Toyota approved coolant and a good mix.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by theburna
    Just a couple of hints for you, as I have just done the water pump on my parent's VS...
    There is a diagram of how the drive belt goes in the manual that comes with the car, if you have that. As already suggested, stick with the genuine GMH coolant concentrate with a 50/50 mix, and don't forget to add the coolant pellets, which from memory, help seal the water pump bearings/shaft.
    Harvs82
    Sep 2004
    You need to take the engine number with you to get a pump,2 different pumps in VS and they go by eng #.
    May 2004
    darwin
    VR Statesman
    Jan 2004
    Wyee
    I just use standard grease on all gaskets, its an old mechanic trick to keep a gasket in place
    May 2004
    darwin
    well, i've got the new pump and coolant and gasket sealer stuff.
    problem - how do i get the old gasket off? if has stuck in places and is being difficult. i got fed up with the knife and chisel, and now dad is trying a scraper blade.
    is there an easier way to get rid of it?
    May 2004
    darwin
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    I replaced my water pump at 150,000.
    Now my VS has 225,000 on it and water pump has gone again, wtf?
    I even had a coolant flush a year ago...
    maybe I didn't do it often enough?
    you would expect at least 150,000 out of a water pump eh?
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
    DANROE101 is offline Dan DANROE101 Executive
    Commodore VR 1994
    Jul 2008
    Default overheating
    My VR is having trouble to, My temp guage says that its still cool and the fan isnt kicking in, I tested it and its drawing to much current, got the old man to test the PC in the car and everything is fine. The Radiator is fine to, there is plenty of water in it, however the other day I got home and there was steam pouring out from under the bonnet after only 5 minutes of driving? I think it might be the water pump but I am unsure?
    Has anybody else had a similar problem?
    Let me know.
    VrWagz1's Avatar
    VrWagz1 is offline The Wagon on Wheels.. VrWagz1 Monaro VrWagz1 Monaro
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Sounds like a dud thermostat to mee or maybe a blocked radiator. Try flushing the cooling system and replacing the thermostat. See the how to section
    Reaper
  15. #15
    1996 VS Caprice V8. 1996 Proton satria.
    Jul 2008
    Seaford, Victoria.
    Quote Originally Posted by holden#1 View Post
    exact same thing happend to mine, except i replaced it at 180thou and it shat itself again last week at 214thou.
    It's one of those jap ones from supercheap, i dunno if their any good????
    The all new TATA Nano, India's $3000 low cost car, Runs on Chicken Vindaloo!
+ Reply to Thread
  1. Water pump ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 09:46 PM
  2. Water Pump
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 10:34 AM
  3. Water Pump
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-04-2006, 09:09 AM
  4. Water pump gone...
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2006, 07:12 PM
  5. Water Pump
    By CALAIS 6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-11-2005, 08:35 PM
