gotta put dat braided hose around my fuel lines. can i jus disconnect em n alls good or is ther a special way![]()
Check out my ryde!!!
http://www.cardomain.com/ride/2040074
ohhh yeah.....only milk and juice come in 2 litres![]()
just dont bend any of the pipe were the hose connects too, and make sure its really depresurised, u may be drining fuel if u dont :P
how do u depresurise it
cheers mate thanks for da help
r u talking about the fuel lines from the firewall to the rail and the return line then you'll need a special tool to remove the lines from the connector at the firewall
the rubber fuel hoses that run to the rail and the return line have a plastic coating tube inside which breaks if u bend it too much......
