wildfiremaint
- Jan 3, 2006
- 321
- 165
- 43
- Location
- Sydney
- VR SS , 2007 Subaru LIBERTY Wagon
Hi everyone,
I need to adjust the ignition timing on my VR SS 5-litre. The sticker
on the strut tower shows that it should be 10degrees BTDC. It also
says to ground the Diagnostic Terminal located under the dash and then
the Engine Check light will flash.
How do I recognise the Diagnostic Terminal connector ?
What then - do I start the engine and then adjust the Distributor
for the 10deg using my timing light ?
Thanks.....
Thanks.....
