Results 1 to 14 of 14
Thread: Vr Wont Start!!!
    Vr exec
    Aug 2005
    Arrow Vr Wont Start!!!
    Hi All, I have had this problem for the last 3-4 weeks and it is giving me the sh**s!! When the engine gets hot (it also does this when cold at times) it cuts out and will not restart for at least 30min and has giving me code 49. I have replaced Crank Angle Sensor and Cam Angle sensor and DFI Module and i am still getting the same problem.. This time it gave me Code 46, i dont know what else to change and what to do.. P.S a new ecu was also put in but has not solved the problem.. Has this happend to anyone else??? Could it be the Fuel Pump??
    VS II V6 Berlina
    Nov 2005
    can i recommend pulling the wiring harness off the DFI module and resizing all the terminals. i have previously seen them spread too wide and not contact with the DFI terminals correctly and because of this can make car hard to start and throw codes for crank sensor etc. get a pick and close gaps on terminals and then a 2.5 or 3mm drill bit will regap them correctly. you might also want to do the same with the ECU (behind L/H/F kick panel) check and regap terminals.
    Code 46 - No Reference Signals While Cranking, so i reckon it will more than likely be DFI terminals.
    hope this helps and i'd try it before replacing fuel pump as its free
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    Code 49 - Cam / Crank Shaft Signal Intermittent
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    VY S2 Berlina
    Jul 2005
    hsvpgts "Code 46 - No Reference Signals While Cranking, so i reckon it will more than likely be DFI terminals." you meant 49 right?
    Current: My Ride
    Previous: Ride 2
    Vr exec
    Aug 2005
    Default Still No Luck
    I had the fuel pump and filter replaced today and still cuts out while i am driving,
    I have replaced and checked
    -Fuel Pump
    -Crank Angle sensor
    -Cam angle sensor
    -DFI Module
    -Checkd wiring
    -ECU ok
    Coils ok
    Is There anything else?
    I have been to 4 mechanics and no one seems to know what is causing this problem
    rooty Guest
    mmm sounds like the problem that i had with my vs i replaced the fuel pump all that stuff and happend again when it starts then cuts out then wont start for like half an hour is it like choking like tryint to get more fuel mine was a wire leadin to my fuel pump was doin the same thing would start sometimes but not others.....
    VY S2 Berlina
    Jul 2005
    hm, who replaced the crank angel sensor and cam angel sensor, you can buy them dodgy, and if an unqualified person installed it they may have installed it rong
    Current: My Ride
    Previous: Ride 2
    Vr exec
    Aug 2005
    Exclamation still cuts out
    a mechanic has installed all the parts and they are all genuine holden parts!!!
    this is the 3rd CAS i have put in thinking that it may be faulty
    VX SS 5.7 M6
    Oct 2004
    Western Australia
    how about a faulty memcal, replacing the ecu is one thing but if it's the actual memcal....
    Just a thought anyway
    Winner of Girl with the Most Horsepower
    Antilag Dyno Comp Saturday 4th Dec 2004
    2x VS
    Jul 2005
    Quote Originally Posted by tommo824
    Yeah but are you dealing with a qualified Holden mechanic ?
    By the sounds of it you're being ripped off by being charged for something that doesn't fix your problem... from 4 incompetant mechanics
    Why not book it in for a quote to fix the car at Holden ?
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    Vr exec
    Aug 2005
    I have found it!!!! it ended up being my dfi module!!!! the one that was put on was obviously dodgy as the terminals that conect to the coil packs were not comeing up with a reading when it was hot but if i wiggled the terminals a little it showed a reading!!! once the module got hot the insides expanded causing them to loose contact.
    Which leads to my next question, was it just a fluke that my dfi module was faulty or what caquses them to die????
    I have a 'couple'
    Jan 2005
    Bris
    Not sure why they die, but it happens. Mine was replaced 6 months ago after intermittant stalling problems and I've heard of it happening frequently (esp in VL's).
    VY S2 Berlina
    Jul 2005
    was your dfi module the mechanic installed brand new?
    Current: My Ride
    Previous: Ride 2
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    the connecters for both the wiring loom and the dfi module get corroded easily...
    common problem on VR's (had the same issue) replace with gold plated connectors, better conductivity, and won't have movement under heat. Costs little but work takes a while, so thats where your cost comes in if you do it at a shop.
  1. VX wont start
    By _VX_S_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 02:50 PM
  2. VS V8 wont start
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 11:39 PM
  3. It just wont start...
    By VL86Berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 07:08 PM
  4. why wont it start???
    By only-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 03:15 PM
  5. Help wont start
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2005, 05:16 AM
