futronix
- Sep 29, 2005
- 202
- 2
- 0
- Age
- 44
- Location
- Melbourne
- 2012 VE SV6 MY12.5
posted a few threads about my problem but havent got any real ideas on wats wrong with it.......
VS commie acclaim running duel fuel......
Runs perfect on gas!!!
Problem is on Petrol.....
sputters and hardly runs on idle except when u open the throttle..... runs to about 40km/h no probs but no power when the throttle is opened up! just acts like its gettin no fuel......
had the following done:
fuel pump replaced
fuel filters twice
injectors done some time ago
fuel pressure test done.. fuel pressure was too high (replaced fuel pressure regulator)
Now there may have been a chance that a previous mechanic had taken off the throttle body and may have played with the TPS (Throttle position sensor)
would the problems im describing be because of the TPS???
How can it be tested to see if it is out??
how do you get it back to factory??
B4 I fork out $$ to get a diagnostics done will the test show if the TPS is out or if it is a Computer problem??
Cheers in advance...... :unsure:
fuel pump replaced
fuel filters twice
