fitzy2005
- Jul 27, 2005
- 1,971
- 12
- 0
- Location
- Wide Bay, Queensland
- VY S2 Berlina
since day one i bought ym vr commodore (v6 auto) i have had a "stalling" issue.
History: i replaced fuel pump,filter,regulator,(now the fuel system is fine - pressure tested etc)replaced a coil on the coil pack, replaced all the leads and spark plugs for the 3rd time, ran a few bottles of injector cleaner through, running premium fuel now though, service (oils coolant filters etc) bought a cold air intake and k&n panel filter(loving it )new battery and alternator(was hoping it was only ythe battery that was screwed but wasnt )new throttle position sensor and iac valve and MAP sensor(cleaned throttle body about 3 times now - off car,)and alot of suspension work has been done.
ok now, all of that has helped a heap with the "stalling issue" what happens is 1 outa 10 times i start the car, the revs are really low, i mean just a little over the first bar (500), soon as i change it into a gear,(rev or drive) the car stalls, ive had a problem with the ignition barrel not wonting to release my key (i gota wiggle it a fair bit then i can get it out,) ive been checkign my computer for error codes every week, and nearly every week i get error codes 12 (system ok) 31 ( Code 31 - Theft Deterrent Signal missing) i just went into holden and they said that your ignition barrell sounds like its on its way out, and they said that can cause the car to stall etc.
Do you guys agree with this? or think its something different causing the car to stall, and also how much do you think a new ignition barell would cost?
cheers for your help
