hi i have a problem with the way my car sits.
well looking from the front:
the front right hand side wheel sits back more than the other side - about 10mm towards the back gaurd comparded to the left front, and makes the car about 10mm higher than the left side , which is also making the back right hand side sit about 15mm higher than the left side,
so if you can picture it looking from the front the whole right hand side sits higher, worst on the back.
i think it is because recently i hit a curb pretty hard on that side, is it posssible to bend your front strut back offsetting the back aswell????
i'm hell confused please help!!!
is my strut just bent or is my car twisted, or i dunno, help??
ImIImI
Most cars should sit about 10mm higher on the right side to compensate for the drivers weight when in the car. But the fact that you hit a curb and the wheel sits back a bit - I'd get that looked at. Most places should give you a free inspection/quote
ok i might of put it a bit wrong, its the passengers side that sits higher. which i meant the right
ImIImI
