Missfiring under load??????
slick_red_VN
39
viewbank
VR Acclaim S2
Can anyone shed some light on my situation.
Only happens after turning a corner or a roundabout but not always.
When i put the foot down it will kick back take off but all of a sudden it hesitates and miss fires for a second or two.
Thought it could have been my dfi and coil packs after i changed the plugs and leads. After replacing the dfi and coil packs it is continuing to do it.
Wondered if it was just when my fuel was low but filled it yesterday and it still happened. Could the fuel pump be giving way?
Or maybe even the ignition module or my ECU.
I havent checked my codes yet but the engine light doesnt come on at all
Anyone experienced this before?
Has happened in my old vn but the dfi and coil packs fixed it
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
fuel pump or fuel related
fitzy2005
VY S2 Berlina
and im guessing by ur title you have another vn? wot is your car, manual auto v6 v8 year etc
fitzy2005
VY S2 Berlina
if its a vn the guys in vn-vp section may be able to help you better then us vr-vs ;) cheers
slick_red_VN
39
viewbank
VR Acclaim S2
i cant work out how to change my user name
i had a vn sold it now i got a vr acclaim
i put a chip in it and had dramas before i reset the ecu then it was ok but he problem was occuring before the chip but it may be contributing i am unsure
sorry mate at work takes me a bit to reply
K
kalkon
Guest
Could be spark plugs breaking down under heavy load could also be a crossfire from HT leads or dodgy leads letting go under light load
slick_red_VN
39
viewbank
VR Acclaim S2
its got new plugs leads coils and dfi i am thinking the fuel pressure regulator diaphram could be giving way or the fuel pump itself is cutting in and under under heavy load but it doesn't always happen
