to test the coil block (V6) :
1) remove each coil one at a time....
2) turn upside down and check resistance between (primary) two terminals
3) should read between 0.3 - 1.5ohms (When Coil is cold!!)
4) measure the resistance between the two terminals on top of the coil (secondary)
5) should read betwwen 5000-10000ohms (when coil is cold!!)
not exactly sure on prices for a new DFI I thought it was around $200.00 from Holden and if im right comes with new coil packs...
or if u want to make sure it is the DFI... do what i did and swap one around from another VS to test..... you could even swap the whole DFI and coil pack still attached to make it easier.
