E
enhancepc
Guest
Misses In First >>>FIXED<<<
First post hello!
Ive been lurking for a while and Ive fixed a few problems with hints from the board with my vr sedan but this ones got me stumped!
the car- 1993 vr sedan v8 m5
the problem- in first when i stand on it i get up to about 3 maybe 4k rpms and the engine starts to buck like im turning the spark on and off...
sometimes in second was then blowing the fuse (fixed see 3.)
what I have done to "try" and fix the problem-
1. crimped fuel return no change
2. replaced cap rotor leads plugs air filter no change
3. replaced oil presure switch (stopped blowing fuel pump fuse!)
(also changed oil and filter) otherwise no change
4. replaced fuel filter and pump and pump filter no change
5. replaced hall effect sensor and replaced ignition module and coil no change
6. replaced coolant temp sensor no change
7. cleaned throttle body and IAC
8. cleaned battery terminals replaced alternator regulator checked earths ok no change
9. removed and checked connectors to computer wiring looks ok no change
10. checked error codes none all 12's 12 12 12 12 12
Got me stumped! any ideas? thanks in advance!
p.s i did do a search and had a few ideas but as you can see none of them have panned out! :b:
First post hello!
