ELECTRIC FAN CONTROL
Circuit Description: The V8 engine has a water pump driven radiator fan incorporating a semi-fluid hydraulic fan clutch. This engine-driven fan provides the primary means of moving air through the engine radiator. On vehicles equipped with air conditioning, an additional electric motor driven fan is placed in front of the A/C condenser. The electric fan(s) will be turned on when the engine cooling fan relay is energised by the PCM. Electric fan(s) will be "ON," controlled by: PCM, if any of the following is present:
- Engine coolant temperature exceeds 110 degrees C. (After PCM turns fan "ON," it will run until coolant temp. is below 105 degrees).
- An engine coolant temperature sensor failure is detected (see DTC 14 or 15 Chart).
- A/C request signal is received and vehicle speed (VSS input) is less than 64 km/h.
- Field service mode is active. (Ignition "ON," engine stopped, and DLC diagnostic "test" enable terminal earthed).
From the above it sounds as if your fan isn't working. If the coolant temperature sensor was faulty (and it may be) it should have caused the fan to come on rather than causing it to stay off. As fabz has suggested in an earlier post, disconnect the fan and test to verify that it's faulty (replacement cost is around $120). The coolant temperature sensor is on the front of the inlet manifold, is an easy replace and relatively cheap (<$20 from memory).
