Results 1 to 4 of 4
Thread: Bonnet Latch
    Feb 2004
    Has anyone else ever had a problem with their bonnet latch?
    mine has always worked fine until a couple of days ago when i tried to open it and it wouldnt pop open i had to get someone to pull the lever from inside the car while i pushed down on the bonet to get it open.
    the latch appears to work properly while the bonet is open
    has anyone got any tips on how to realign the bonet?
    thanks
    Gavin
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    Smile
    there are adjustment bolts where the brackets are that the bonnet sits on or you could just tighten the cable as they do strech over time dont ask me where to do this as i dont know but there is something somwhere
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I found that its basically a adjust the centre bolt and try and keep going with that its a bit finicky until you get it right .It obviously got too much tension on it now so loose a bit and try unless someone w( a mate playing with it while the bonnet was up )has screwed the rubber stops out on the ends of the front corners on the bonnet on you without knowing what they were doing so check this out first.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    shsvstewart_8 Guest
    there is another way, being an Auto elec and working on site alot have to impravise, it seems a bit crude, but at the same time as pulling bonnet latch inside car with your left hand give the bonnet a slight tap with your palm of your hand...... hasnt let me down yet
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet Latch
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2012, 12:30 PM
  3. bonnet latch replacement vn
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2007, 07:22 PM
  4. Bonnet Latch prob
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 03:20 PM
  5. Boot Latch Is Stuck
    By Du`ranain in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-10-2003, 08:09 PM
