evil_monkey
ok well its back to the drawing board i thought i might of had a buggered water pump, turns out the one thats in it is brand new, we went for a drive on sunday weather was hot but car didnt overheat came back and noticed coolant leaking out of the overflow hose any ideas ??? the coolant is at a fine level not over or under i was wondering if i should go ahead and do the thermostat the only thing im worried about is i was reading in the user manual of the car that the cooling system has air leak points ???? have no idea what that is but when i took the engine cover off i noticed on top of the thermostat housing that there was like a brass screw with a seal on it, perhaps the air leak point ?? all i do know is in the manual it says if your doing a major change of coolant or anything that it needs to be bleed and to take it to holden dealership something i am so not doing any help would be much apreciated :w00t:
