When i fill my Fuel tank up to full i get a strong smell of fuel into the cabin.
Is there a mod or easy fix for this.
Cheers,
Steve
check fuel regulator vacuum hose for petrol if yes replace itOriginally Posted by cleggy88
check carbon canister and assosiated hoses for crackes
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
check the exhaust.
There are small hoses about the width of your pinky finger which return fuel vapours. These are really crappy and will deteriorate really badly. This will normally leave you with a fuel smell after you fill up. I have a sedan and have replaced one or two of the hoses behind the drivers side rear wheel panel but i think you will need to take it to a mechanic to drop the tank out, unless you are competent to perform it yourself. This may not be your problem, but thats a problem i had when i found a fuel smell.
Common fault with utes. Clear breather comes out of black rubber hose at tank. Remove tank cover in ute back for good access (lots of screws) or move drivers seat forward and remove small black cover on rear wall behind seat and look in there. I'm an ex Holden Mechanic so done heaps of them. Easier to do than describe.
