Results 1 to 4 of 4
Thread: Front Brakes - Weird Noise when Breaking
    VS Calais
    Oct 2005
    Melb : Australia
    Unhappy Front Brakes - Weird Noise when Breaking
    Hey all...
    Well this has been a problem for quit some time, havnt taken it to get looked at yet.
    The problem is, that when im applying the brakes to the car to come to a complete stop, when i hit about 20km or less & its about to completly stop, the brakes make this weird noise, like a cracking or creaking noise, its hard to describe the noise.
    The discs are fine & dont need machining, just wondering if anyone had any ideas? Some one suggested the front bearings? Anyhelp before i get it looked at appreciated.
    ben
    VS Berlina Wagon
    Mar 2004
    Melbourne, VIC
    Happens to me as well, mostly after the daily commute to/from work. The pads get 'glazed' and make the squeaking/grating/grinding sound when they reach a certain temperature.
    My trusty mechanic says the way to fix it is to brake more aggressively ;-) which will bring the pad temps up and help to remove the 'glazing'. This does work, after a couple of heavy stops from 80 clicks the sounds stops, at least for a week when the glazing seems to come back. Oh well.
    If you're really concerned try another brake pad compound (softer/harder).
    Cheers,
    DP
    VR S Ute Manual
    Dec 2005
    Central Coast
    Yep, the same happens in my VR. If you only brake slowly the noise is there, when you really pound on the brakes theyre silent.
    deathsminion's Avatar
    deathsminion is offline Chrgd,Coold,Twinthrot'in
    GT42R forced JZA80 Supra and VT Wagon
    Oct 2004
    Mine started doing this after I put Bendix Ultimate pads in.
  1. weird pulley noise coming from front of engine
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 12:37 PM
  2. Weird clunking noise from front of car
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2011, 12:38 AM
  3. weird noise need help
    By bMcgrath84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2005, 04:07 AM
  4. weird noise
    By Hinchman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2005, 07:09 PM
  5. Weird Noise
    By Melfice01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2004, 02:15 AM
