S
sherr
Guest
Hi everyone i hope someone can help . I went to start the car today and the ignition lights came on and the car did not start and i could not turn the ignition off. after removing the cowl from around the column and removing the ignition switch from the lock assembly i notice that the keyway from the lock to the switch had snapped. Q1: is this keyway replaceable if so how do i remove it from the lock Q2: how do you remove the lock from the column to replace it.
Thanks
Steve
Thanks
Steve
