+ Reply to Thread
Results 1 to 2 of 2
Thread: Fog Lamps. Need Help
    WK statesman 5.7, VS exec TURBO
    Sep 2005
    mornigton penisula VIC
    Default Fog Lamps. Need Help
    i am wanting to install fog lamp into my VSII Equip.
    i Know where to get all thew bits but i want to know...
    can enyone give my a guide on how to do the wireing for the lamps and for the LED on the lamp switch? Thanx
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Your car should have the wiring under the bonnet for it ...if it does it will have the 2 pin plugs that go to the lights themselves taped back near both the head lights and the relay base and relay under the relay/fuse cover.This is the diagram for the wiring under the bonnet The wire that is violet /red ( I think I called it pink/ red in this diagram by mistake ..it should be violet red) but it should be there that goes from the relay base through the firewall to the dash connector plug. You need to run a wire from the plug to the switch and tee off existing wires to fog switch connector above .heres the diagram for it
    This is the diagram for the wiring at the dash plugs beside the fuses inside the car.The wire that comes from the relay is the violet/red wire on connector 124.Ignore the wiring connection directions as thats for installing a L3 dash . I have put this in just to show you the dash wiring connectors .
    Another thing I found is the connector you need to install that plugs into the fog switch itself is the same in size and type as the air cond switch one.
    If you get stuck I could make up the wiring with the plugs you need from spare stuff I have here .You have to make a few tee solder wiring connections as in the second diagram.
    This thread might be a help too.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
+ Reply to Thread
  1. Fog Lamps wiring
    By Loupy31 in forum Electrical Wiring / Questions
    Last Post: 13-11-2007, 11:13 PM
  2. Fog/Driving Lamps
    By Marzz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-11-2006, 07:11 AM
  3. VT/VX fog lamps
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2006, 09:18 PM
  4. WTB: VX Calais Fog Lamps
    By VX_BERLINA02 in forum Swap / Wanted to Buy / Trade
    Last Post: 14-06-2006, 05:49 PM
  5. Fog Lamps...
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2006, 03:55 PM
