I
iamdvs
Guest
My car has been suffering the same problem for a long time now and I'm at the end of ideas as to what could possibly be wrong.Basically the car just doesn't want to start and when it does there is a strong fuel odour.I have changed the fuel regulator,fuel filter,battery,bought a new key,cleaned out the throttle body,changed the TPS,checked spark plugs,checked ECU codes now I've been thinkin all along it's the fuel pump however people have dismissed this.The car has no problems and plenty of power once in motion but it seems to just start when it pleases regardless of whether the motor is hot or cold.So basically the key must be held on for at least 10 seconds and then the motor decides to start up very rough, at this point it will either stall and the procedure will have to be restarted or it will run normal.
