Results 1 to 12 of 12
Thread: How Long Does It Take !!! ?
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    Default How Long Does It Take !!! ?
    ok people ive been having a problem latly of rough start rough idle and very high fuel consumption and black smoke from exhaust its a 1996 auto vs v6 exec series II
    injectors cleaned
    spark plugs changed
    leads changed
    coil pack changed
    throttle body cleaned
    coolant temp sensor changed due to fault code 76 after sensor changed fault code is gone still idle rough start rough use lots of fuel and blow black smoke
    service done oil/oil filter
    fuel filter changed
    both oxygen sensors just changed and still blowing black smoke starting/idling rough not burning oil
    how long does it take for the oxygen sensors to kick in ?? is this something that takes a little while to happen or is it instant im at a loss i didnt make the sensors super tight when i put them on because i didnt want to strip the thread but id say they are to tight to take off with your fingers
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    its most likely ur air flow sensor, in the VR its the MAP sensor located on the firewall, not sure about the vs
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    Aug 2005
    *bangs his head against the wall* well i guess its a trip to holden tomorrow
    Mr Invisible 55 Guest
    Post Vs
    Hey It could be the fuel you are using it could just be a bad batch just try it for a while and see what happens tryu changing fuel stains and so on because i know some one wh had a vs and it did the same thing and it turned out to b the fuel
    RYAN
    if u found this advice useful click on the scales
    Aug 2005
    Aug 2005
    Quote Originally Posted by Mr Invisible 55
    RYAN
    thanks dude but its definatly not fuel ive learnt harsh lessons with my first car the vn commy, i always run premium in it and i always get from the same petrol station my vt is runnin on petrol from the same station as the vs, and the vt is running like a dream
    vr calais v6
    May 2004
    colyton nsw
    i had same problem with vr v6 i found that my car on startup would realy struggle to start and run rough for a couple of seconds and would blow black smoke as well , all i did was change the fuel pressure regulator which is on the back off fuel rail and it has eliminated the hard starting , rough idol and black smoke as there is a diaphram inside it to which it was letting to much fuel through hope this helps
    Aug 2005
    looks like vs's dont have a MAP sensor after a few hours of banging my head against a wall trying to find it they have something simular called the MAF sensor which is attached to the air intake hose i pulled it off and it looks real clean almost newish so yeah i doubt its that
    Aug 2005
    so i guess its the fuel pressure regulator which i didnt really want to replace if it isnt that i think we are just going to have to douse the car in petrol and set it on fire
    Aug 2005
    this is pathetic, changed fuel pressure regulator no more black smoke no more rough idle still starts like crap though
    VY S2 Berlina
    Jul 2005
    most likely the fuel pump, get a pressure test done on the fuel system, i had the same issue, ended up being the pump not holding enought pressure, pump = replaced problem = gone
    hopefully this helps you, because i no how annoying problems like that can be take for ever to figure out!
    Current: My Ride
    Previous: Ride 2
    portercg Guest
    get the pressure test. Not trying to criticize but lots of ppl here just change stuff without getting basic stuff tested. A pressure test will tell you:
    if you have leaky injectors or non-return valve.
    if you have a regulator problem or fuel pump problem
    Lots of the stuff evlmonkey replaced has nothing to do with his problem.
    I think it would help if tech qualified members posted some home disgnostic info for various known problems our cars get.
    Do you feel that would be useful?
  1. How long will you keep your car????
    By AttaBoy in forum The Pub
    Last Post: 09-03-2007, 05:23 PM
  2. how long
    By vq_statss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 09:03 PM
  3. how long?
    By HoZy in forum Car Audio
    Last Post: 22-03-2006, 09:51 AM
  4. Vt long trip
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2006, 01:50 AM
  5. how long will it last
    By mutant in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2006, 02:56 AM
